| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
This is my first post on here so I'm not sure if this would be the right area.
Anyway In a couple weeks some friends and I are going to float the salt river it takes about 5 hours from top to bottom and I have been trying to figure out a way to build speakers into the cooler and either connect a head unit or just use a waterproof iPod case and connect them to that.. One of my main problems in the power supply I'm not sure what to use that would last 5 hours and still be cost effective.. after all this is pretty much just a novelty item. I would appreciate anyones ideas of thoughts.. also input from anyone who may have made one of these in the past... I would like this to be as inexpensive as possible while still retaining as much cooler space as possible. |
#2 |
Wait, you are going to enjoy the bounty and sounds of nature for 5 hours, and would rather try to drown it out with music?
Your ears should be stapled to your butt as punishment. edit... I forgot the smilies |
#3 |
Anyone have any ideas on how to build this?
#4 |
You could use a car head unit connected to a 12 volt battery pack. some of these things are high capacity, should last 5 hrs no problem.
http://www.globalsources.com/manufac...tery-Pack.html
My DIY audio projects- PartTimeProjects.com. |
#5 |
Why not use a car battery? Float it in a big cooler or make a raft to hold it, a couple of old house speakers from a thrift store or yard sale, and a small 2-channel car amp. Use an RCA-1/8" cable to connect the iPod directly to the amp, and seal the iPod inside something very waterproof... poke a hole in a Tupperware container and seal the cable with generous amounts of hot glue or RTV. The amp will probably have a volume control on it if you need to adjust the volume and don't want to unseal the iPod.
| Modifying an old Radio to accept an MP3 Player - help needed | FoleyF | Digital Source | 3 | 25th June 2008 10:03 AM |
| noise from a cooler (two different ones) | facundonu | Chip Amps | 12 | 6th July 2006 12:09 PM |
| peltier cooler | karma | Swap Meet | 6 | 5th December 2005 12:55 PM |
| Fan cooler for JLH 10W a-class | adirax | Solid State | 3 | 15th May 2004 10:21 AM |
| CPU cooler for amplifier | Circlotron | Solid State | 16 | 27th December 2002 10:58 PM |
| Page generated in 0.08606 seconds (73.45% PHP - 26.55% MySQL) with 10 queries |
