Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th April 2007, 01:13 AM   #1
Circlotron's Avatar
Default Cap types and sound quality
Article based on engineering facts.
Link
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 20th April 2007, 01:42 AM   #2
jcx is offline jcx  United States
-with a premise of only considering crap to begin with
no one interested in quality would consider "class 2" ceramic in a audio signal path
even mylar would be superior and avaliable in 1210 pkg at the tested 1 uF, 16 V value
likely even al electro of 10uF value would be superior in similar case size
Old 20th April 2007, 07:32 AM   #3
Nordic is offline Nordic  South Africa
Nordic's Avatar
The article was good I think.
It clearly relates to PC sound hardware, states the obvious footprint problem, and serves as a guide to manufacturers as to which of the components available in that size would produce the lowest THD etc...
I.e. not which cap is the best, but which carateristics would make one cheap (mass production utilisation) capacitor a better choice than the next with the goal being Vista Certification.
When considering capacitors for the audio-signal path, select capacitors with X7R dielectrics for better THD performance. Although X5R dielectrics outperform Y5V dielectrics, X7R dielectrics offer the best—that is, lowest—THD among Class 2 dielectrics.
The space, height, and cost restrictions typically associated with portable consumer electronics force the use of passive components with small footprints, low profiles, and low cost. When you use them for audio-signal coupling, some small-footprint, low-profile, low-cost passive components can limit low-frequency THD performance in audio circuits. However, doing so compromises audio sound quality and jeopardizes Vista compliance. Despite their slight footprint and price premium, large-footprint ceramic capacitors with high voltage ratings and X7R dielectrics are the best choice for all passive components in the signal path for a Vista-compliant audio design.
Old 20th April 2007, 08:58 AM   #4
this doc starts with the premiss that only HiK ceranic will fit the footprint left available on the pcb.
Seems she is recommending the best of a bad lot.
I note that the spec she is trying to meet limits frequency response (and distortion measurement targets) to -3db at 20Hz and there are some other specs that cut off at 100Hz.
What happened to the CD bass rolloff of -3db at 4Hz?
Is the DVD bass response even lower down at about 1Hz or 2Hz.
Looks like microsoft and maxim are aiming pretty low with their premium audio systems.
regards Andrew T.
Old 20th April 2007, 09:50 AM   #5
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
diyA DIY PC sound card anyone ?
Looks like Sponge Bob has killed another thread.
Old 20th April 2007, 02:23 PM   #6
Nordic's Avatar
Most diy PC sound cards sem to be offboard, so free from the restrictions...portable media is another matter...
Old 20th April 2007, 04:01 PM   #7
Tweeker is offline Tweeker  United States
The Vista compliance shackles take up a whole lot of the board space.
Be sure your foil hat has a good low impedance ground.
Old 22nd April 2007, 01:53 AM   #8
Circlotron's Avatar
My interest in the article was not regarding ultimate fidelity, but that it sets out good reasons why not all capacitors sound the same.
Old 22nd April 2007, 05:28 AM   #9
Vista ? Eeeeeeeeeeeeeeeek
http://www.boreme.com/boreme/funny-2...he-book-p1.php
Best possible sound quality from +12 ATX PSU Arnop Chip Amps 3 6th April 2009 11:40 AM
Better Sound Quality LqDFx Car Audio 14 16th June 2006 04:49 PM
Orange drop types/sound lndm Parts 3 20th March 2006 03:46 AM
Quality Control differences = variations in sound quality? KT Class D 0 14th November 2004 06:51 AM
TAD sound quality Kal Multi-Way 12 6th April 2004 06:16 PM
Page generated in 0.10304 seconds (75.95% PHP - 24.05% MySQL) with 10 queries
