Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Need a high quality volume control
Old 20th April 2007, 01:52 AM   #1
audiovista is offline audiovista  Serbia
Default Need a high quality volume control
Well, very high quality, in fact....for test application, which means constant manipulation.
I am looking for a dual volume pot, preferably audio taper, but will consider linear taper if better. Major criteria is durability.
Application is tube noise tester and the potentiometer must not mask the tube noise.
I looked at ALPS, typical life is 15,000 cycles. Looks good till compared with Bourns, who claims 25,000 cycles, but couldn't find dual pot. That also looks good till compared with MIL grade pots claiming 2.3 million cycles - no dual config either.....
NOBLE used to make good ones, but can't find any info now.
Value 20-100k, I can work around that.
Price is of little practical matter, but can't use switched resistors, TVC or similar, has to be a dual (ganged) potentiometer (size constraints).
Any suggestions?
Many thanks,
Boris
Old 20th April 2007, 03:03 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Default Re: Need a high quality volume control
Originally posted by audiovista
Well, very high quality, in fact....for test application, which means constant manipulation....
Any suggestions?
Many thanks,
Boris
Why can't you use switched resistors?
You can't do any better than a DACT switched resistors potentiometer.They are used or are designed for the most exactiing instrumentation applications.Check out the Danish Interconnect Company.Google and you will find out more.
Linear or taper if they don't have it you can ask to customise.
Old 20th April 2007, 04:24 AM   #3
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
Even if you get pots with long life, that doesn't guarantee the matching of resistance in dual pots.
You could probably use a gear belt to drive two or more pots. Check W. M. Berg for the parts.
Audio attenuator ICs offer good matching and they are a LOT cheaper than pots.
I_F
Old 20th April 2007, 12:02 PM   #4
Singa and I-Forgot,
Thanks!
There are size restrictions that pretty much eliminate anything but ganged pots. Matching resistance is of the lower importance than pots useful life. One way to deal with matched resistance is switching to linear pots.
I will check companies that you suggest as I'm not familiar with them.
Thanks again,
Boris
Need a high quality volume controlHide this!Advertise here!
Need a small quality volume control lionking7 Parts 2 14th May 2009 02:41 PM
quality tone/volume control space2000 Solid State 6 13th March 2008 03:47 PM
how is the quality of a chip-based volume control VS normal stepped attenuator? jarthel Parts 4 16th July 2007 03:40 PM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 01:25 AM
Cheap high quality volume control for BOSOZ jag Pass Labs 3 22nd August 2002 08:25 PM
