Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th April 2007, 11:44 PM   #1
jarthel is offline jarthel  Australia
Default ground wire very close to ac wires
is it okay if I "twist" my ground wire around mains wires. The ground wire is going to the ground-loop breaker.
any comments?
thank you.
Old 20th April 2007, 12:11 AM   #2
where is it coming from and after the ground loop breaker where does it go?
regards Andrew T.
Old 20th April 2007, 12:22 AM   #3
1 end of the ground wire is connected to something like this: http://www.dse.com.au/isroot/dse/ima...cts/p4850.jpg.
The other slots are taken up by the live, neutral, AC ground and B+. Another 4 is taken up by wires to connect to a motor run cap.
After the ground loop, it goes nowhere else.
Old 20th April 2007, 06:32 AM   #4
Hi J,
you've lost me.
One end of this wire goes to a terminal block and the other end goes to a ground loop breaker and then nowhere.
regards Andrew T.
Old 21st April 2007, 12:25 PM   #5
Hi J,
you've lost me.
apologies for not being clear.
the terminal block has 2 holes.
1 hole has a black wire that goes to the ground loop breaker. there is nothing else connected after the ground loop breaker.
the other hole has a black wire that is connected to B+ ground.
simple se ground to speaker wire? pforeman Tubes / Valves 4 27th July 2009 01:13 PM
What does the phono ground wire actually ground? kirk57 Analog Line Level 7 30th May 2008 07:20 PM
why does teflon insulated wires need a very expensive wire stripper? jarthel Parts 7 30th April 2007 02:53 AM
No ground wire in my electrical outlets (USA).... darkmoebius Parts 5 28th June 2005 10:30 PM
Acoustat AC ground wire connection noelm Planars & Exotics 7 21st June 2005 08:44 PM
Page generated in 0.08692 seconds (72.76% PHP - 27.24% MySQL) with 10 queries
