| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
as title. thank you.
#2 |
Yes.
Be sure your foil hat has a good low impedance ground. |
#3 |
Here, one of the many ref. tables from internet
http://www.powerstream.com/Wire_Size.htm
My System |
#4 | |
I have seen that before I created the thread. I am confused with the rating they gave. 11A for Maximum amps for chassis wiring and 1.5A for Maximum amps for power transmission The 20AWG wires will be used for powering paralleled tube heaters. |
#5 |
This means that if the filament transformers are in your treehouse and not on the amp chassis, you need a bigger wire.
Voltage drop is a bigger concern to you, but the wire itself can take quite a bit of current. Most PTFE wire is good to 200C. Resistance is .033 ohms per meter. For heaters it will be fine, it might be thin in the case of it feeding a 2.5 amp average current to a capacitor input rectifier. It could readily take it, but circuit considerations might suggest heavier wire.
#6 |
I sell quite a bit of Green PTFE/Teflon wire in 20 Awg
for heaters in tube amps so there should be no problems. Steve @ Apex Jr. |
#7 |
Steve realizing you wire is "surplus" :
what is it mostly, guessing MIL W-22759/? and similar? Dave
intentionally blank |
#8 |
Most of the teflon I stock is the M 22759/ 11
or Mil M 16878/4 all 600 volts, however when buying you also get the thin wall 150 or 300 Volt or the thick wall 1000V stuff too... I also have some solid in 22 and 20 Awg too... Steve |
| hook up wire | Original Burnedfingers | Tubes / Valves | 5 | 12th January 2009 06:34 AM |
| Hook up wire? | cjkpkg | Tubes / Valves | 12 | 23rd November 2008 11:55 AM |
| Hook-up Wire? | mwh-eng | Tubes / Valves | 6 | 4th March 2004 07:30 AM |
| PVC vs. teflon wire | RobPhill33 | Solid State | 4 | 27th January 2003 09:10 AM |
| Hook-up Wire | Cambe | Parts | 0 | 2nd October 2002 04:58 PM |
| Page generated in 0.50221 seconds (19.79% PHP - 80.21% MySQL) with 10 queries |
