| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
is the tip the left channel and the middle one the right channel?
I found something like that in a wiki but wiki entries can be made by anyone so I like to verify their contents. thank you. |
#2 | |
#3 |
Yes again.
And the barrel is ground (common).
* Bibo, ergo sum. |
#4 |
the way I remember it is:
Ring = Right = Red As in Tip, Ring and Sleeve. |
#5 |
thanks for the help
#6 |
while we're on this topic, does anyone have a source for stereo headphone jacks (preferably 1/4") that DON'T connect ground straight to the chassis? i'm trying to build a linestage/headphone amp and would rather not cut out a square to mount PCB to insulate it..
#7 | |
cliff components (http://www.cliffusa.com/) has them. not sure where you get them though. http://www.cliffusa.com/datasheet/1-...%20SOCKETS.pdf |
#8 |
Or Bulgin or Rendar, or any number of generic Far Eastern 'plastic block' types. Try your local music shop...
"I never did care for music much; It's the high fidelity!" Flanders & Swann |
| Thread Tools | |
| Need help with headphone jack | DJelly | Everything Else | 3 | 22nd July 2009 06:39 PM |
| 4 Pin Amp output to 3 Pin headphone jack? | StrayS2k | Chip Amps | 3 | 17th February 2009 05:46 PM |
| headphone bypass jack | nukaidee | Chip Amps | 9 | 3rd February 2009 08:38 PM |
| adding a headphone jack | Bama Slamma | Solid State | 1 | 13th March 2007 02:36 PM |
| Can I add a headphone jack to BZLS | tomchaoda | Pass Labs | 8 | 30th September 2003 12:58 PM |
| Page generated in 0.16021490 seconds (78.87% PHP - 21.13% MySQL) with 10 queries |
