| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
![]() Hi, I just picked one of these up for a reasonable price off eBay. It turns on, and I get a dot in the middle, but I have no probes or anything. I found and downloaded the service manual, but have yet to make heads or tails of it. First off, does anyone have any recommendations for probes that I should try picking up? I don't know what else to do to make sure the thing works, I assume that fooling around with my CD player's output once I have probes should give me more of an indication... |
#2 |
soren
Ideally a x1/x10 probe or one of each. Can you get a verticle trace with no probes? Select say 500ms on the sec/div and 500mv on the volts/div.Select channel 1 DC and you may have to adjust the trigger control a bit. Dave
Ret. USAF... AKA- Avionic *** Solder slinger for hire...*** |
#3 |
#4 |
That don't look good
If you dont mind me asking ! I hope it was a real reasonable price-I take it ,it was (as is) needs work price. Dave
#5 |
$50 or so including shipping. I was actually anticipating having to do some work on it. Should I pop the cover and take a look?
#6 |
Well it looks like a vertical sweep problem.What have you got to lose.
Dave
#7 |
Be careful.I'm sure your aware of very high voltage on the CRT .
Dave
#8 |
Yeah. There's a little cluster of Sprague .01uF 4000V caps near the wire headed to the anode of the CRT
repair the Tektronix 2213 oscilloscope,service manual? but I'm not positive that his and my problems are the same. |
#9 |
Flipping the thing over, I saw a few areas with burned components. The Sharpie writing on the board confirmed my suspicions that someone else had tried to service this scope. A bunch of screws are also missing from the chassis, and some of them looked a bit chewed up. I guess he wasn't very good at repairing things...
| Tektronix 475 oscilloscope - gone bad | Urban | Parts | 10 | 10th June 2011 05:46 PM |
| Will start my new Gainclone from Start, Need Help | samsagaz | Chip Amps | 4 | 27th May 2008 09:39 AM |
| Will I kill my Tek 2213 | guitvinny | Equipment & Tools | 12 | 16th May 2006 03:17 AM |
| Tektronix 916 DVM | ANTHONY2181 | Swap Meet | 0 | 6th October 2004 11:44 AM |
| repair the Tektronix 2213 oscilloscope,service manual? | X.G. | Parts | 23 | 13th June 2004 07:10 PM |
| Page generated in 0.09827 seconds (75.52% PHP - 24.48% MySQL) with 11 queries |
