Go Back   Home > Forums > Commercial Sector > Vendor Forums > Parts Connexion
Parts Connexion Electronic parts and lots more http://www.partsconnexion.com
Old 23rd May 2013, 04:54 AM   #1
spuddo is offline spuddo  Australia
Default unobtanium---little help
Hi All , a little help needed finding the following.
These are used in synthesisers---old ones.
LS3954A---dual n chn jfet TO-71
UA726HC--temp controlled diff pair---10 pin can
E402------dual n chn jfet TO-71
Geoff
Old 1st June 2013, 12:29 AM   #2
scott wurcer's Avatar
Geoff
Really? There are diff pairs MAT02 or from THAT corp. that will certainly sub for these. I can't see an audio application that actually needs ultra DC stability, very strange.
“The earth's rotation will slow within days and stop for several days just prior to the pole shift. This is when you and your loved ones should be situated at your safe location.”
Old 1st June 2013, 12:34 AM   #3
Sprags is offline Sprags  United States
I work with jet engine components that are made from unmachinabilium.
Old 1st June 2013, 02:04 AM   #4
Hi , scott. The Ua726hc is used with VCO's that require temp stability or everthing will sound like the Sex Pistols . The Mta02 been tried , it's not a straight sub.
Geoff
Old 1st June 2013, 03:31 AM   #5
benb is offline benb  United States
More specifically, it's for the exponential converter in the VCO.
I googled the part # and ... long explanation short, I'd rather redesign for a currently made device than ...
I see from the datasheet, that thing includes an on-chip temperature regulator as well as the two transistors. I remember the Micromoog used an LM3046 this way, it's still made in SOIC, and NOS DIP parts should be available cheap. Here's something about using it:
Re: uA726 replacement, (the comedy of errors)
Here's a temp-regulation circuit using a multitransistor array, it should work as well (or as badly) for the LM3046:
http://www5b.biglobe.ne.jp/~houshu/synth/ExpPent.gif
Old 1st June 2013, 04:30 AM   #6
Hi Benb , reading the ua726 replacement article is enough to put paid to that idea,
The piece of equipment i'm repairing is a minimoog and no way would i diy a sub--it deserves a drop in replacement.
As it turns out, last night i managed to get a nos part .
Old 1st June 2013, 11:34 PM   #7
Geoff
I've worked before with guys restoring classic stuff, I understand that re-engineering is frowned upon and NOS replacements are the only acceptible solution. Though if Diana Krall sounded like the Sex Pistols it would be an improvement.
God Save the Queen.
Old 2nd June 2013, 12:44 AM   #8
Hi Scott , Diana Krall is now on my "to avoid at all costs " list.
God save the Queen , yes but which one -Andrew, Edward or Charles
Old 21st July 2013, 07:24 AM   #9
Try utsource.com to get some uA726. The 726 has a powered heater in the IC to keep the dual transistor section at a stable temperature; there are no other similar devices of which I'm aware. Be sure to check/test the 726 you get from ut; they take returns if they're fake.
Bridechamber have the LS3954A but it's $12.00 each:
Hard 2 Find ICs
Try getting a quote on 2N3954A from questcomp:
Quest Components Part Details
Quest are a great company and are very helpful with rare components and good quotes.
Old 21st July 2013, 02:48 PM   #10
Hi tape echo , thanks for your reply. How do you test the UA726 Hc out of cuircuit , i need them to build a vco but am at a loss as to how to check them before building.
The irony of all this is that 12 months ago i sold 18 that had been sitting around for a decade or to two---thought i'll never need these---DOH.
Thanks for the links.
Geoff
AN7060 Unobtanium issues... Want to find similar to drive Darlington Power ICs SVI2004A Chip Amps 7 1st October 2012 04:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
