PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Konzert Amp & Speakers Website
Old 26th March 2010, 01:02 PM   #911
zrolsky is offline zrolsky
Originally Posted by Jef3 View Post
sir, i think both of these stores can give a discounted amount of 14400 each for the sd 18el try negotiating.
1) xstatic. contact numbers are 02-3854822, 09228067041. they are situated in sucat paranaque.
2) ml rapacon. kamias corner anonas quezon city. contact numbers are 02-9291754 or 09228987031.
how i wish this discount scheme also works in P Audio, Cebu City distributor. Indeed, this will encourage, and will be of great help for DIYers in the south.
Old 26th March 2010, 02:03 PM   #912
dj_jojo_md is offline dj_jojo_md  Philippines
dj_jojo_md's Avatar
Send a message via MSN to dj_jojo_md Send a message via Yahoo to dj_jojo_md
General
Number of input channels 2
Number of output channels 4
Peak total output all channels driven 20000 W
Max. Peak output voltage per channel 194 V
Max. output current per channel 67 A peak
Max. Output Power 2 ohms 4 ohms 8 ohms 16 ohms
All channels driven 4800 W 4400 W 2300 W 1150 W
Channels 1 and 2, while channels 3 and 4 are driven at -3 dB 1) 5000 W 4500 W 2300 W 1150 W
All channels driven into optimal impedance interval > 5000 W into 2.2 – 3.3 ohms
its not 20kw per channel...
excerpt from PLM 20000Q Technical Data
the same with Crown Macro Tech 10000...only this one has a lot of juice down to .5 ohms...this is 3 phase Ac powered...this is mono...and this is a discontinued product.
have nice day
jojo
lets get back to DIY, and have fun...
Old 26th March 2010, 05:56 PM   #913
anatech is offline anatech  Canada
anatech's Avatar
Hi Guys, Tony,
Thank you.
More people can respond if they can read and understand. Don't take this to mean that you can't also post in your native language if your are unsure how to convey the exact meaning either.
I hope I didn't come off as the language police either. I don't use "that hat" very often, and it's a tribute to the members here that I don't.
On to amps 'n stuff.
i am a believer in not putting all your eggs in one basket...multiple smaller amps is better than just 1 single amp.....
and the reason for that is not all of them will fail at the same time in use....
I agree completely. As a servicer, I'm no fan of huge repair jobs (= expensive) either. Multiple amps are easier to control for one. A short in one of the speaker feeds is also easier to locate if they are split between many amps. Then there is how you get rid of all the heat.
On the flip side, you'd need a truck to run off with one of these large amps!
Best, Chris
"Just because you can, doesn't mean you should" © my Wife
Old 26th March 2010, 10:10 PM   #914
urbanista is offline urbanista  Philippines
Post W-Bin(sub-zero) VS Sub Scoop
Good Day to all,
I'm a planning to buy or make a sub woofer Box, for my mini sound system, that can be used in small Gigs, like in a covered court, I am thiniking of which sub box to use between a sub-zero(wbin) and a sub-scoop. And I plan to use a TNT 18's and a sventa MA10.
With this two boxes, i am courious which of these sound better.
Any recomendation from you guys, on which box i will use, will very much appreciated,
Thanks in advance.
Old 27th March 2010, 02:07 AM   #915
Post speaker plans
Good day to all,
Can any one send me a plan for the following BINS,
L36
w-bin(sub-zero)
sub scoop
Here's my email (urbanista2007@yahoo.com)
May i ask is TnT 18's speaker are suitable for these bins.
thanks in advance,
Old 27th March 2010, 06:07 AM   #916
Jef3 is offline Jef3  Philippines
i think the discounting varies depending on the quantity that you'll order.
will it (still) be cheaper to buy the stuff coming from manila?
Old 27th March 2010, 06:15 AM   #917
Originally Posted by urbanista View Post
Good day to all,
L36
w-bin(sub-zero)
sub scoop
thanks in advance,
sir i think some members here have already been using those enclosures. just try to review earlier posts
as for the TnT woofer, try to ask for the TS parameters if it can be optimized on those enclosure types you mentioned
Old 27th March 2010, 12:42 PM   #918
you are right, it depends on the quantity of orders. from manila, perhaps not. but if really for great quantity, and especially for an OEM type of order, perhaps the best option is this.
but it needs money, more more and more money.
File Type: jpg this is perhaps the cheapest way to do it.jpg (198.0 KB, 770 views)
Old 27th March 2010, 07:13 PM   #919
@jef3
Thank you sir.
do you have a plan for the sub-scoop bin.
thanks again
Old 27th March 2010, 07:17 PM   #920
Default @jef3
Thank you sir.
by the way can you send me a plan for a sub-scoop bin, if you have one.
thanks again.
Konzert Amp & Speakers WebsiteHide this!Advertise here!
