PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Konzert Amp & Speakers Website
Old 11th July 2009, 04:09 AM   #641
Garyepe is offline Garyepe  China
Garyepe's Avatar
Send a message via MSN to Garyepe Send a message via Yahoo to Garyepe Konzert Amp & Speakers Website
Default Reply
Hi Sir,
If you need Electrionic Components or products,please let me know.
I am in China. Can find the parts that you need .
By the way, we also can do business by paypal.
B.Regards
John Gu
Old 12th July 2009, 11:58 PM   #642
arnelb is offline arnelb  Philippines
@audiomachine
Ok sir thnx, i got it. So, what model of a crown speaker would you recommend sir? And what brand is better than crown in it's price category? Thanks again
Old 13th July 2009, 07:23 AM   #643
@ garyepe
Sir, how much for a ca20 soundstandard amplifier including shipping to Philippines?
Old 14th July 2009, 01:20 PM   #644
audiomachines is offline audiomachines  Philippines
Send a message via Yahoo to audiomachines
@arnelb
sorry for the late reply, T&t would be a good contender against the crown speaker in a price category, The dual spider system of T&T makes it more durable. But it doesn't mean it sounds better than the other.
audiomachine
Old 15th July 2009, 07:03 AM   #645
@audiomachine
Thank you sir. I'm planning to buy an additional 4pcs. this coming december.
I know you're always there to help us, thanks again.
Old 25th July 2009, 02:17 AM   #646
toygianan is offline toygianan  Philippines
@ audiomachine
good day. i am having a problem with my setup. i am using a preamp equalizer with a mono sub xlr output. using 8ohms tnt sub speakers and 1000w power amp, all xlr output, the performance is ok. i then substitute a 4ohms pyle sub speakers 300w, using a variable 4-8ohms 500w amp, still using xlr output, it seems no sound is coming out of the speaker. however, when i substituted a preamp crossover using rca/pl plugs, it sounded ok.
can you help me identify the problem and solve it?
thank you.
Old 25th July 2009, 04:50 AM   #647
@toygianan
probably cabling issues, balance to unbalance connection since you mention an RCA plug. Please check the connection.
XLR to RCA
Pin
1. Chassis Ground - Shield or outershell
2. Hot - Tip of the RCA Plug
3. Cold - You can terminate it (to ground) with a 10K
resistor if you like or just leave it floating
Best Regards,
audiomachines
Old 25th July 2009, 06:30 AM   #648
@ Audiomachine
thanks.
Old 5th August 2009, 03:22 PM   #649
rainier17 is offline rainier17  Philippines
Talking Question about KONZERT sub-woofer...
Hello everyone...
New member in this website. I just want to ask something. My brother bought 1 pair of KONZERT 8" Professional HI-FI SUB-WOOFER, Dual Impedance:8 ohm . 8 ohm 250 WATTS PEAK 25 OZ MAGNET (KW-880M) from his friend. My question is how to assemble this sub-woofer and what others parts do I need to buy? Do I have to buy capacitor for this sub-woofer? If yes, what value of capacitor will I buy? Any one more thing... at the rear of the speaker it has a 2 pair of terminal. (+ and - ) and another (+ and -). What is the purpose of those 2?
Old 5th August 2009, 11:45 PM   #650
@rainier17
Welcome aboard! the two terminals on the back on the subwoofers means that the speaker has a dual voice coil. You can parallel the two voice coil by connecting + to + and - to - giving you a 4 ohm impedance.
Since your subwoofer doesn't come with the a T/S parameters
I will give you a rough estimate of the box/baffles dimensions.
Sealed Enclosure (no port)
height X width X depth = 11inches x 11 inches x 8 inches
Ported Enclosure (bass reflex)
11 inches x 20 inches x 8 inches
with a port diameter of 2.5 inches and length of 11 inches
You can use a PVC pipe for your port/s
You can bent the port tube using an elbow because it will exceed the depth of the box.
Your box will be tuned now around in the 35-40Hz area, good enough for your subwoofers. You can line the internal walls of the box with a 1/2 inch thick foam to serve as a damping materials.
hope this helps.
Best Regards,
audiomachines
Konzert Amp & Speakers WebsiteHide this!Advertise here!
