PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Konzert Amp & Speakers Website
Old 23rd May 2009, 11:41 AM   #601
lizgar is offline lizgar  Philippines
Banned
Originally posted by engel dela pena
kung meron mag share pls.email me @
engel9mcnaly@yahoo.com
thanx
I have copied from orig circuit from Magus PO-800 it has been xerox the orig circuit with the pcb.. and etch it..
Old 28th May 2009, 01:34 PM   #602
EMX_125 is offline EMX_125  Philippines
EMX_125's Avatar
Send a message via Yahoo to EMX_125
hi...MGR
Meron ka bang circuit diagram 150w by Edmund wong?
EMIX
Old 28th May 2009, 07:39 PM   #603
MGR is offline MGR
I have the original diagram of the 150 watt amp I will try to have it scanned this weekend.
Old 29th May 2009, 12:42 AM   #604
EMX_125's Avatar
thanks for the reply MGR....
if im not wrong i think this 150w amp by edmund wong the circuit is similar to old westrak amp But im not sure. this westrak amp is available in sta cruz manila ( raon street ) MGR ill will be waiting your post of circuit diagram......
thanks........
EMIX
Old 29th May 2009, 03:22 AM   #605
black_gulaman is offline black_gulaman  Philippines
hi
where can i buy westrak amplifier? any comment from this amp?
can i already buy finish product? or kit only? how much it cost?
thanks
Old 29th May 2009, 02:27 PM   #606
tronblitz is offline tronblitz  Philippines
MGR,
I've been using this amplifier unit since 1995 to drive my 2pcs 18"400w crown woofers & started a small sound system business. About 5 years ago I bought 2pcs 18"1000w crown woofers(1860) and assembled another E.Wong's stereo amp & I plan to upgrade this to reach the voltage rail around +/-90~100VDCmax to utilize my high voltage caps.(1,200uF/160Vx20pcs) also to increase power. I have collected power amp schematics like qsc, leach, holton, etc. just for reference but mostly has no complete details in calibration & has hard to find components & very costly unlike this amp.
I have read about topics of amps bought in Quiapo & I am having the idea on what clone brand to buy that is cost-effective for my 1860 drivers.
By the way thanks for the info.
tronblitz
Old 29th May 2009, 02:27 PM   #607
to sir audiomachine
hi, can you give me idea of this
im building my diy mid high monitor 2 way speaker, in parallel connection for both speakers. my question is
what is the ideal or for best result for this is speaker separate amp for each speaker? or parallel connection and then connection to amp? low budget only i prefer parallel connection
what value of capacitor should be place in high speaker ?
mid speaker is 300W nominal- 500W max
High speaker 150w nominal- 300w max
i think your bright idea will help me
thank you
Old 29th May 2009, 10:32 PM   #608
audiomachines is offline audiomachines  Philippines
Send a message via Yahoo to audiomachines
@black_gulaman,
my suggestions are:
1. If your woofer is utilizing a 2.5inch voice coil then the HF section should be also be utilizing a 2in ~ 2.5inch voice coil.
2. minimum 2nd order hi-pass filter for the HF section.
3. You can have a " large toggle switch" mounted on the terminal cups (where the speakon connector is also mounted) so you can have a choice of passive full range or Bi-amp mode.
4. Use a smooth curvilinear cone for the woofers for that extra mid hi "presence"
5. Have a dedicated processor for the monitors 1/3 octave eq, comp/noise gate. Monitor speakers demands more processing than the FOH speakers.
Hope this helps.
regards,
audiomachines
Old 30th May 2009, 07:10 AM   #609
@Audiomachine
If im using active XO do i still to connect the cpacitor in my HF?
your suggestion enlightened me
thanks
Old 30th May 2009, 11:37 AM   #610
@black_gulaman,
yes you still need to connect a cap on the HF section, just as a precautionary measure. Glad that I can help sir.
regards,
audiomachines
Konzert Amp & Speakers WebsiteHide this!Advertise here!
