| PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc. |
#1851 |
transformers designed for 50hz will have more primary turns than a traffo designed for 60hz, it will run cooler when operated at 60hz.....
http://www.elab.ph/forum/index.php?topic=32688.0 |
#1852 |
Sir Tony...good days po.. to you...i just want to ask you if...the diagram you given to be can be supplied with +-100V...the modified AV502...
thanks...benny |
#1853 |
#1854 |
yes, you will have to change your trannies to ones with min Veo rating of 200volts or more....
#1855 | |
Just wanna ask, whats the use/purpose of of the cover (whole being reduced) Nways, are the Cerwin Vega cabinets are more boomy? what are the characteristics of this cabinets.. thanks |
#1856 | |
JE-36C CERWIN VEGA FOLDED HORN SERIES SPEAKERS SUBWOOFERS |
#1857 |
#1858 |
#1859 |
ukiuki
#1860 |
To Sir Jojo,
At your Constant Pressure Site, what plan exactly is the BP118, RCF of ACM? |
