PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Konzert Amp & Speakers Website
Old 13th August 2011, 11:10 AM   #1731
wattaniya is offline wattaniya
final decision, will u share or not yr amp pcb?
because hereafter no body will ask pcb layout in pdf from u.
Old 13th August 2011, 11:14 AM   #1732
Skyjham is offline Skyjham  Philippines
as i've said this is our business so we don't share it.i think this is not a good forum for business, once agian i'm sorry admin,
pls. delete my post
Thanks!
Skyjham
Old 13th August 2011, 01:37 PM   #1733
yaden is offline yaden  Philippines
I think your amp is bridge it is not stable at 4 ohms its shurly has dc output and crell . lexus use the same curciuts those two amp are not stable at 4 ohms when in battle alway burn voice coil yours is the same.
Old 13th August 2011, 03:54 PM   #1734
no thats not bridge pls. take a look at the schematic of K10 and compare, we know what we are doing
Old 13th August 2011, 04:17 PM   #1735
If this is what you mean,
yes this is bridge on both channel, this is what we used last Dinagyang,
Our latest power amp is a modefied K10, K10 using only 2 switching transistors, 7 for outputs we make it 4 for switching and 8 for outputs and change some components at the bias and driver section, we also change the buffer.
Old 13th August 2011, 04:37 PM   #1736
Ah ok but still look at your power supply not enough capacitors and transformer you use old e-core not good for a powerful amp better use a trodial transformer and many caps so you can load down to 4 ohms. good luck !
Old 14th August 2011, 01:27 AM   #1737
LOL thats already computed if you know how to compute the power needed in specific amp.
thats capacitors are enough coz the value is 22,000Uf not 10,000 Uf . do not question us about our design we know what we are doin.
any transformer will do if you know how to compute the desired power. for your amp.
Old 14th August 2011, 02:25 AM   #1738
romulo_rosil is offline romulo_rosil  Philippines
[QUOTE=Skyjham;2671106]LOL thats already computed if you know how to compute the power needed in specific amp.
Your transformer is too small, not enough to handle in two amps even your caps. How much total wattage in your amp of 8 ohms load stereo?
Old 14th August 2011, 02:42 AM   #1739
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
so how did you compute your power requirement vis-a-viz your power traffo? mind sharing?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 14th August 2011, 02:44 AM   #1740
This is our first transformer and capacitors use in that amp, we try to change with a small one and monitor the supply voltage and yet not flactuating, so we decided to assemble that way.
Konzert Amp & Speakers WebsiteHide this!Advertise here!
