PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Konzert Amp & Speakers Website
Old 28th February 2011, 04:53 AM   #1501
VolMax Audio is offline VolMax Audio  Philippines
@dj_jojo_md
Sir, I have just built a WSX box base in your post at diyaudio. i have a problem about distorted flocking sound which is i think it's due to the rectangular hole in the mounting speaker area. the force of the cone is trapped which causes prrrk! prrk! prrk! sound. what is wrong in it? sir jojo please help . .please help from anybody
Old 28th February 2011, 09:59 AM   #1502
@dj_jojo_md
Old 28th February 2011, 11:40 AM   #1503
dj_jojo_md is offline dj_jojo_md  Philippines
dj_jojo_md's Avatar
Send a message via MSN to dj_jojo_md Send a message via Yahoo to dj_jojo_md
Originally Posted by VolMax Audio View Post
@dj_jojo_md
mga DIY speaker cabinet users/builders post your pic here
1. You need to check if you drivers cone is not touching the module or else you need to place a 1/8" sitting pad to increase the height allowance.
2. make sure that you dont have any air leak...remember that this is a "sealed" horn loaded box...if you lose the vacuum the driver will over excursion to its mechanical limit.
3. make sure that all joints are firmly glued at screw together...if not...when the cab starts to pressurize this could cause unnecessary sound.
4. be sure to screw all complete 8 holes of the driver and properly tighten.
Have a nice day,
jojo
Old 28th February 2011, 01:15 PM   #1504
1. = no it doesn't touch the module, anyway 18mm marine plywood has 5 ply, i remove 2 ply in the rebate of speaker displacement, is this ok or take out 1 more sir?
2. = over excursion to its mechanical limit? this probably my problem. . . i tried to change the driver from TnT to Crown and it was good, suddenly after 2mins of playing the music @ normal volume, a krrrt! krrrt! sounds came out and the sounds got off. i checked out the driver, it's been stack, the cone doesn't play anymore. i cant smell any burnout from it. i'll be checking it 2morow what really is.
(2yr old tnt sounds krrrt!, krrrt! along the way, compare to 11 yrs crown)
Sir, what do you use to sealed the top cover?
thank you very much,
VolMax
Old 28th February 2011, 01:35 PM   #1505
@dj_jojo_md
sir kindly check my attached thumbnails, is that what you call DOVE TAIL? that's the way i make my boxes. . .
Old 28th February 2011, 08:01 PM   #1506
dj_jojo_md's Avatar
VolMax
1. rebate is ok...just add 1/8" (lawanit will do) sitting pad/spacer to give more allowance for the driver excursion.
To seal the cover...use a cut-off strip of rubber foam...you can buy this from any Shoemaker Store that sell all kinds of rubber materials...to adhere use a contact cement or double adhesive tape.
Magandang araw,
jojo
Old 28th February 2011, 08:13 PM   #1507
dj_jojo_md's Avatar
@dj_jojo_md
This is how dovetail joint are done.
Magandang araw,
jojo
Old 28th February 2011, 08:53 PM   #1508
dj_jojo_md's Avatar
@ebadilles
Here you go...
Magandang araw,
jojo
Old 1st March 2011, 08:39 AM   #1509
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay Konzert Amp & Speakers Website
@ebadilles
Here you go...
Magandang araw,
jojo
Do you have measurement for 15 inches speaker with this design?
Old 1st March 2011, 09:19 AM   #1510
dj_jojo_md's Avatar
That is 2X15"...Sir.
Magandang araw,
jojo
Konzert Amp & Speakers WebsiteHide this!Advertise here!
