Konzert Amp & Speakers Website - Page 145 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 21st January 2011, 01:57 PM   #1441
Send a message via Yahoo to audiomachines
Originally Posted by VolMax Audio View Post
sir, what really is the essential of using D.I boxes? how would it be its contribution to your system. kindly explain further sir. thanks. . .
using D.I. boxes means you can plug in your guitar amps, bass amp, keyboard board amps directly to the mixer (mic or line level, depending on the level setting of your D.I box) this means fewer mics to manage on the stage, therefore you have "more control" and cleaner audio, since the signal is directly coming from the internal amplifier of the instrument amp, on a miked instrument amp, the open mic will pick up unwanted stage noise, nearby monitors (which will cause feedbacks) and also the other instruments on the stage (bleeding) I hope this answers your questions sir
Old 22nd January 2011, 06:29 AM   #1442
dj_jojo_md's Avatar
Send a message via MSN to dj_jojo_md Send a message via Yahoo to dj_jojo_md
@Volmax Audio
This is a very simple draw showing you how to use 1 3way xover splitting them to have an Aux fed Sub in mono mode.
If you what me to elaborate the drawing, please give me time...
Maraming salamat,
jojo
Old 22nd January 2011, 11:06 PM   #1443
@dj_jojo
thanks sir, i can relate to your drawing. . .
some said that making your mid in full range will be better, they don't get it from the mids out of the croosover rather connect it to eq from mixer main left or right. just asking about it. . . thanks sir. . .
Old 22nd January 2011, 11:13 PM   #1444
@AudioMachine
"plug in your guitar amps, bass amp, keyboard board amps directly to the mixer"
but you can do this by taking it directly from the line out of the amps, correct me sir if i'm wrong,. . salamat po. .
Old 23rd January 2011, 12:12 AM   #1445
dj_jojo_md's Avatar
@dj_jojo
That is IF the Mid/Hi tops are 2way passive (not 2way active) then you have to set your xover into a 2way configuration...
Magandang araw,
jojo
Old 23rd January 2011, 12:45 AM   #1446
@AudioMachine
yes that is the idea, the but the signal would be unbalanced (+,GND making it vulnerable to noise plus it could introduce ground loops (i.e the mixer is plug to a different wall socket than the instrument amp on the stage) the D.I. box would convert the signal into a balanced signal (+,-,GND) plus isolation, ground lift facilities,gain adjust and impedance matching
Old 23rd January 2011, 01:41 AM   #1447
sir, where do you often connect the compressor? what particulars need compressions?
i only use compression sparingly, but it is essential if our pastor is loud during sermons..
Old 23rd January 2011, 02:48 AM   #1448
t68kv is offline t68kv  Philippines
@eirol_99
what speakers and amps brand did you use in your church? If you don't mind.
Old 23rd January 2011, 07:17 AM   #1449
Originally Posted by t68kv View Post
@eirol_99
jbl control contractor series speakers and qsc amps
Old 24th January 2011, 01:40 AM   #1450
@AudioMachine
oh I see. . . sir, my friend uses D.I boxes before the input of the amplifier, where really it should be; guitar to D.I box to guitar amplifier to mixer or guitar to guitar amplifier to D.I box to mixer? thanks and God Bless. . .
Copyright 1999-2017 diyAudio
