| PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc. |
#1421 |
dbx subharmonic wont be useful kasi your wsx goes low enough, lalo na set up mo na 8 WSXs per side, lakas na nyan,
mid high, would be 2kHz provided your compression drivers can go that low.. experiment, use your ears and ask your companions which sounds good in your settings |
#1422 | |
mid to hi xover...900hz ~ 2khz...it depends on your passive network and Driver Horn cut-off frequency. Picture please...16wsx... Last edited by dj_jojo_md; 19th January 2011 at 07:09 AM. |
#1423 |
dj jojo md,
how about your 50cent about post #1405? |
#1424 |
#1425 | |
i forgot to take pictures when i do blessing and little bit of disco. thats y maybe my soud tech turm down the bass boost of the dbx. and he try to boost the eq from 60 to 120hz. i cant relay so much of ear mid you sentonado. sir did you used spectrum analyzer to set up your eq? my mt122 uses 12inch jackhammer woofer and tdu 500 horns. for the compression driver i used 3.2uf and 5 ohms 20 watts resistor in series. |
#1426 |
@audiomachine
@jojo sir, pls help me buy the right one, i'll be buying 15" plastic floor monitor tommorow, i only have budget at around P5000 to 1 pc and i need to buy 2 pcs. which is 10k more or less... what brand is best for that value; crown, kevler or any other which you would recommend? need your asap response. . .thanks. . any respond from any one? Last edited by VolMax Audio; 19th January 2011 at 10:15 AM. |
#1427 | |
Magandang araw, jojo |
#1428 | |
Smaart software/measuring mic with pink noise generator to flatten the response. for the compression driver i used 3.2uf and 5 ohms 20 watts resistor in series. Not safe...you have to put an inductor coil to filter out low freq. then an L pad circuit for the gain control of the driver. Magandang araw, jojo |
#1429 | |
do i still need to do like that for the compression driver even if i crossover it at 2khz? just asking sir. |
#1430 |
@ dj jojo
sir it is ok to run sub at low sum rather than left and right sub connection. pls give advice. |
