PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Konzert Amp & Speakers Website
Old 8th July 2010, 10:03 PM   #1011
dj_jojo_md is offline dj_jojo_md  Philippines
dj_jojo_md's Avatar
Send a message via MSN to dj_jojo_md Send a message via Yahoo to dj_jojo_md
mtl2 a product of electrovoice during the 90's...its a discontinued product.
here's the spec sheet from ev...
have fun
jojo
Old 9th July 2010, 01:51 AM   #1012
eesbiboi is offline eesbiboi  Philippines
eesbiboi's Avatar
Default do we have amps to DIY to run this piece of monster???...
hi guys...
pardon to interrupt...
i'm just wondering...
i saw this speaker in an electronic store just yesterday when i was buying components for my diy amp...
i was really shocked with that guy hanging with those other guys...t'was like" hey... i never saw something like this before"...
it was a SOUND BARRIER 18" speaker which is 2200w @ 8ohms...with a magnet diameter of about 12"...gosh!!! i didnt get to see its voice coil diameter...
do we have something to diy just to turn this guy ON???...
tnx...
regards...
Old 9th July 2010, 03:25 AM   #1013
rhodrich is offline rhodrich  Philippines
@esobe
wich store incebu you find this speaker?
Old 9th July 2010, 05:38 AM   #1014
eesbiboi's Avatar
Originally Posted by rhodrich View Post
@esobe
i found them at AC?DC electronics located at manalili cebu...
i sound barrier is a bit pricy...
15" 1200w @ 8ohms cost much...i guess t'was 8500 pesos...
18" 2200w @ 8 ohms would be much expensive...:cr azy:
Old 9th July 2010, 03:07 PM   #1015
arnold manuel is offline arnold manuel  Philippines
[QUOTE=smblite;2238012]HI all,
I am newbie here I just wanna ask which is better to use in subwoofer mt2 or wsx, If I used 1850 speaker driver will work in mt2 box? and anybody used the mt2 box? I`ve seen this set-up in manila med. concert bass, is good But I dont know which driver they used.
regards,
smblite[/QUO
Folded horn design is far more better than those manifold technologies if you are doing outdoor sound, if you want to build the wsx you have to build at least minimum of four per side mirror setup to achieve coupling effect becoz it was design to stack into array. Crown 1850 don't have t/s parameter I don't know f 1850 works well in wsx. A speaker with low qts and fs, hi BL and high xmax work well in horn design. Original wsx was fiitted with RCF driver but builders from UK are fitting void18-1000 speaker and they says it plays louder than the original wsx from martin.
Old 11th July 2010, 07:44 AM   #1016
smblite is offline smblite  United Arab Emirates
smblite's Avatar
[QUOTE=arnold manuel;
Folded horn design is far more better than those manifold technologies if you are doing outdoor sound, if you want to build the wsx you have to build at least minimum of four per side mirror setup to achieve coupling effect becoz it was design to stack into array. Crown 1850 don't have t/s parameter I don't know f 1850 works well in wsx. A speaker with low qts and fs, hi BL and high xmax work well in horn design. Original wsx was fiitted with RCF driver but builders from UK are fitting void18-1000 speaker and they says it plays louder than the original wsx from martin.[/QUOTE]
Hi Arnold,
Yes I`m planning to build sound system and looking for compactness subwoofer and I`ve seen this MTL2 posted by jojo and I`m thinking that this MTL2 is suitable in PA touring, But like said I dont knw what driver to use and also measurment of this box.
Maybe I try first the wsx subwoofer becoz I`ve noticed that this subwoofer will work in 1850 driver which is available in our local store, and like you said 4pairs wsx per side is enough for starting.
Best regards,
smblite
Old 11th July 2010, 09:20 PM   #1017
dj_jojo_md's Avatar
samples of wsx stacking configuration...
have a nice day
jojo
Old 12th July 2010, 09:17 AM   #1018
sir jojo,
what a very nice set-up. what kind of speaker box u used on mid high sir. on the top of wsxspeaker
Old 12th July 2010, 11:36 AM   #1019
smblite's Avatar
have a nice day
jojo
Nice set up sir Jojo, I really excited having a sound system like that set up.
smblite
Old 13th July 2010, 07:29 AM   #1020
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
hi jojo
Do u have a design for 12 inches woofer for hifi home use. I have 2 pioneer speakers waiting for enclosure design. I prefer minimized size so as not to occupy a large area. Do you have sir?
thanx....
Konzert Amp & Speakers WebsiteHide this!Advertise here!
