PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Konzert Amp & Speakers Website
Old 26th September 2006, 05:33 AM   #91
clem_o is offline clem_o  Philippines
Originally posted by audiomachines
If you could find the brand name Musik Focus MA400 it is using the same ckt. but with a much bigger torroidal
transformer compared to the K4. Hope this helps.
Where is this available??
Cheers
Old 26th September 2006, 06:03 AM   #92
hienrich is offline hienrich  Philippines
hienrich's Avatar
hi,
as far as I know Music Focus is not in the market any more......
it is then replaced with Sventa....
well my friend owns two and it sound punchy on the low end of the spectrum specially when match with
18 in P-audio challenger series rated 650 watt 8 ohm subs
and it reaaly sounds better than what is
uso in our place, Crell..........
macweb
"to invent, you need a good imagination and a pile of junk..." - Thomas Alva Edison
Old 26th September 2006, 12:14 PM   #93
jayrjoe is offline jayrjoe  Philippines
hi hienrich,
you own the Crell power amps? CA20?
its so much like the CA20 from sounstandard, the casing and the logo CA20 is printed the same as the soundstandard.
Are they a clone of sounstandard?
more power!
Originally posted by hienrich
hi,
macweb
Old 26th September 2006, 01:05 PM   #94
audiomachines is offline audiomachines  Philippines
Send a message via Yahoo to audiomachines
hello guys,
I am afraid I did not find any info about the V12 amp. Sorry jayrjoe.
if your into amps that will eat 2 ohms for breakfast try googling for CrestAudio 10001, 9001. In bridge mode the 10001 can deliver 15Kw of power into a 4 Ohm load. uso dito Phonic XP series amp.
Best Regards,
audiomachines
Old 26th September 2006, 02:39 PM   #95
hienrich's Avatar
i dont know so much about crell
but I listen to it when my friend had a gig somewhere here....
I think it was the Alpha 1600,......not so sure
but it sounds fair anyway
the inside looks almost like Crest Ca series I dont know which
macweb
Old 26th September 2006, 04:04 PM   #96
no problem audio machines, thanks for that info, ive been searching the web, i have seen and viewed some specs of Void infinite 8.
also ive seen the specs of the Lab gruppen amps, 13 KW at 4 ohms.
they are great amps with great power but with great prices, very expensive for home use.
regarding with the V12, i emailed the supplier for the specs. i'll post the specs for some reference guys.
thank you,
Best regards,
jayrjoe
[QUOTE]Originally posted by audiomachines
[B]hello guys,
Best Regards,
audiomachines
Old 26th September 2006, 04:09 PM   #97
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
sorry for the threadjacking but...
Originally posted by clem_o
Re: Spin
Yes, some good stuff there, but not easy to find. The place is terribly underlit... They seem to have less available than before, when it was still called 'crystalsem'.
Cheers!
just been there this afternoon. not much to look at but scored some perf boards, single/double sided FR4 blanks, and some ferrite cores. interesting stuff too. just not had enough time. although I did not find heatsinks that I needed badly, I saw they had toroids used in the 41hz t-amps.
Old 27th September 2006, 12:58 AM   #98
hello,
I got some CrestAudio schemes Vs, CA, Pro Series etc.
If some of you decided to clone one sali ako.
Best Regards,
audiomachines
Old 27th September 2006, 01:10 AM   #99
Is there a hosting service you can post it at?
Cheers!
Old 27th September 2006, 02:26 AM   #100
hienrich's Avatar
gud am to all,
audiomachines what Crest Proseries do have for now....?
actually I need the Crest Pro9002 class h with IGBT on the
higher rails for switching, I just need this one for references
since I plan to go on the H class...
if u got time, my pm is hienrichb at yahoo dot com
macweb
Konzert Amp & Speakers WebsiteHide this!Advertise here!
