| PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc. |
Hello!
My friends and I like to go and party outdoors.. Yet it almost always ends up in a party with cheap music/poor amplification. We have a wide taste in music and would like to take it outdoors. We also play instruments and would enjoy outdoor sessions, and would like it to be LOUD (-: It would be nice to take something like high quality, high volume 4 upper-two-way speakers and 2 subs to the bushes, and party on! Anyone know there are any good exsisting DIY designs for something like this? Thanks! Adam |
#2 |
Banned
You might want to take a look at the DR horns and Tuba subs on my site.
#3 |
Speakerholic
Hi Adam,
Another option is to get some old cabinets and refill them with updated gear like I did. Cal |
#4 | |
Sheesh! Cal, You'll pick up a lot of outdoor useable bass if you put 4x8 sheets of plywood (wings) on each side of those 210's. That was an Altec option. What do your neighbors think?
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#5 |
Speakerholic
Hi rca,
I've oft thought of the plywood wings. Putting them on hinges in fact, so I can fold them back easily for storage. But if you think I'm short of bass well, perhaps you should hear them first. Neighbours? Don't know, I can't hear what they are yelling. Cal |
#6 |
check out www.speakerplans.com
there's quite a few different designs on there from horns to bandpass and direct radiating mid/tops |
#7 |
Cal,
awesome setup! Did you paint those green and blue HF horn flares yourself? /Magnus
"Knowing what to do but not why is no use in a changing world" - The Art of Sound Reproduction |
#8 |
Speakerholic
Hi Magnus,
The horn ports were painted four different colours because I was using up some old cans of spray paint (not kidding). Those are bass reflex ports not HF. They are small bass boxes (dual 10") and they go with the small mid/high units on top. Great for small venues. The A4 and A7 boxes get put together for another system. All together they make up my "Speakerhenge" Cal |
#9 |
So Cal, are you using horn flares as ports? I just assumed they were HF horns 'coz they look pretty much like miniature 2380 flares. Anyway, the color coding scheme would work great for easy identification I guess.
Are there something like an 8'' and piezo horns in the small top boxes? What amps and crossovers are you using for this setup? /Magnus
#10 |
Some nice tall line arrays is what you need. Keeping dispersion within the plain of the array is a huge advantage outdoors. Why play music for the birds flying overhead?
That's why all outdoor or large venue concerts use line arrays. It's easy to get high sensitivity using mulitple drivers, plus the gain in sensitivity vs distance for arrays over point source speakers is tremendous. Within the range that an array acts like a line array, SPL decreases by only 3db for each doubling of distance vs 6db for a typical speaker. That's a 9db difference at 25ft, which is huge.
Everyone has a photographic memory. It's just that most are out of film. |
| Powerful small/thing portable speakers? (battery powered?) | Anirak | Everything Else | 2 | 24th March 2009 09:29 PM |
| Tube Amps left outdoors 24/7 | Robert McLean | Tubes / Valves | 9 | 19th January 2009 05:18 PM |
| Protecting good drivers outdoors | rick57 | Multi-Way | 20 | 21st April 2008 10:23 PM |
| Powerful bass | syl | Solid State | 13 | 2nd July 2007 10:29 PM |
| building 5 way outdoors loudspeakers | ahdcfegb | Multi-Way | 1 | 28th June 2004 02:15 AM |
| Page generated in 0.09788 seconds (89.32% PHP - 10.68% MySQL) with 11 queries |
