| PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc. |
#61 | |
For some real world stuff about cheap drivers in a line array check out my friend Dmitri's site at http://www.geocities.com/dmitrynizh/labaffles.htm A 4-5 driver array works great for a desktop because it's easy to stay within the plane of the array and it's nearfield response. In a room you need taller arrays and because you need the drivers as close together as possible, you need more drivers. Close spacing is essential so the higher frequencies are included in the line array effect. The line array effect is based on frequency, driver spacing, and length of line. Higher frequencies require smaller spacing and shorter lines can project further. Low frequencies can have larger spacing and need longer lines. That's why spacing your bass units apart will work and is needed for the line array to project further. The two reasons I think you need so many drivers are: 1. You want long arrays, so your listeners remain in the nearfield as much as possible because tonality will change if they are in the nearfield at some frequencies and and farfield at others. 2. You want lots of drivers to achieve the efficiency and SPL that you need outdoors. Remember, you wouldn't build a speaker using one of these drivers except maybe for a desktop. If you put alot of them working together like ants, they can be impressive. The tapping cones, etc. is for the woofers, because you are looking for low Fs. I would never consider a 4" driver a woofer. For system power output requirements etc., it's best to invest in an SPL meter so you know what 1 driver can do. It's simple math once that is know. You could get away with estimating this if you already have some drivers of various known sensitivity and doing a comparison. Our ears are amazing measurement instruments it just takes a little training for them. If you can find drivers you like for a great price in your area after listening to a wide selection, success is almost guaranteed. Cutting all those driver holes will be the worst part of the hole thing, so be prepared. My work on arrays has been more rewarding than all of my other speaker projects combined. This is due to all the hands on listening and evaluation, the knowledge gained, plus the end result is very unique and results in alot of feedback and interest from others. First, find some decent drivers and build a mini array pair and see what kind of sound you can get for $20 or less. Keep in mind that the bass and top end may be missing, but those are easily obtainable too.
Everyone has a photographic memory. It's just that most are out of film. |
#62 |
The first link is wrong, check it out...
#63 |
Here's the corrected link to Dr. Griffin's work.
http://www.audiodiycentral.com/resource/pdf/nflawp.pdf
#64 |
I'm in the process of building my own outdoor theater Audio Stuff.jpgsystem. Here is a photo of the muscle of my system. Next will be the high power line array speakers.
#65 |
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#66 |
Hello guys me and my friends made this Outdoor speaker: https://www.youtube.com/watch?v=llLS_k0QwOY
What do you think about it ? Got any experience on how to make speakers with theese horns yourself ? And do you know of any speakers with similar design ? If so please show them. Thanks. |
#67 |
Here are the mid range & tweeter towers for my outdoor system (inside for the winter).
| Powerful small/thing portable speakers? (battery powered?) | Anirak | Everything Else | 2 | 24th March 2009 09:29 PM |
| Tube Amps left outdoors 24/7 | Robert McLean | Tubes / Valves | 9 | 19th January 2009 05:18 PM |
| Protecting good drivers outdoors | rick57 | Multi-Way | 20 | 21st April 2008 10:23 PM |
| Powerful bass | syl | Solid State | 13 | 2nd July 2007 10:29 PM |
| building 5 way outdoors loudspeakers | ahdcfegb | Multi-Way | 1 | 28th June 2004 02:15 AM |
| Page generated in 0.10907 seconds (77.83% PHP - 22.17% MySQL) with 11 queries |
