PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
the "125dB Monster"
the "125dB Monster"
Old 12th July 2018, 07:22 AM   #351
125dbmonster is offline 125dbmonster  Australia
125dbmonster's Avatar
Originally Posted by Max Headroom View Post
Did you get to the bottom of the fault with the DSP box ?.
Dan.
There were a few things I couldn't work around. DC on the outputs I could with removing some slip links inside
Yea, want back a step to my old one, to incorporate FIR Filtering and Group Delay correction introduced a miniDSP Dirac Live 22D Dirac Series : DDRC-22D
to the system .
The other is not going to be used sadly maybe someone else wants it.
You can watch music with your eyes closed
Old 12th July 2018, 08:42 AM   #352
Max Headroom is offline Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
I mean Chris's Analog Precision box.....what's the going price ?.
Dan.
Old 12th July 2018, 08:45 AM   #353
There is nothing wrong with the other dsp. Nicely built and when dialed in would be perfect for all filtering and DAC functionality among other things. The times it was connected sounded well.
To be honest the problems I encountered may be some fault so the answer is no not been to the bottom of the problem
Old 16th July 2018, 04:58 AM   #354
Pleased the rig has been booked for February and April next year.
NewKind Festival. off the grid
John Diesel and the Injectors. off grid
Both are private parties that are either off grid or too far from utility power and both wish for no generators on site if at all possible and in particular run at times performance is on.
Old 16th July 2018, 05:12 AM   #355
Upfront is offline Upfront  Australia
Upfront's Avatar
Good news Matt. Well deserved.
Old 16th July 2018, 05:19 AM   #356
Thanks Linc !!!
Dunno about well deserved but getting on with it, is the plan.
Next job is to modify the rolling dollies for the horns so as I am able to push the whole assembly into corners of the room. At the moment the rear corners muck things up.
Then onto cab refurbish of the 4 x 18" Exidos X's, castors grills and so on.
Old 16th July 2018, 05:29 AM   #357
Upfront's Avatar
Big speakers need large castors mate! 125mm+ I recon.
Old 16th July 2018, 06:44 AM   #358
Yep, the Subs are over 100Kg each and currently require the drivers to be removed for any type of movement point A to point B.
the "125dB Monster"Hide this!Advertise here!
"Hydra" a MONSTER Bluetooth Speaker! sjowett Class D 3 9th January 2018 11:34 AM
8,8 meter basshorn "6090 Monster" Skramstad Subwoofers 150 1st September 2013 03:35 AM
"Monster" Cable vs Monster Vintage MonsterVintage Everything Else 0 18th October 2004 11:35 PM
A Monster "carcase" for sale jackinnj Solid State 3 29th May 2002 11:34 PM
