PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Distortion sound at all volumes
Old 7th January 2018, 05:54 AM   #1
sulan is offline sulan
Default Distortion sound at all volumes
Hi everyone, my first post on this forum so hopefully this is in the right department.
I got a PROEL SMART12MA powered speaker that gives some kind of distortion sound at all volumes.
I opened the speaker and connected the amp to another speaker and same distortion sound appears so I have ruled out that the woofer or tweeter driver is damaged. I also noticed that the original transformer may have been replaced. Looking at the fitting bracket (photo attached) I suspect a toroidal transformer was fitted at factory but somebody have installed 2 smaller linear transformers with the following specs, the first one: 110V-220V 60/50Hz 17-0-17V 2A and the other one 110V-220V 60/50Hz 18-0-18V 2A.
Now I am not sure if this is what causing the distortion sound but if I where to replace it, would a transformer like this one be suitable ? DAC - 24-0-24V X 1, 18-0-18V X 1 - Toroidal Transformer - 434VA
The thing is that there are 2 secondary wiring needed, the circuit board have 2 sides of it where it needs to be connected, one says HI AC IN and the other one LOW AC IN, How much hi and low is supposed to be I am not sure but I have written to manufacturer and hope they will reply.
Any guidance would be appreciated.
Rick
Old 7th January 2018, 07:29 AM   #2
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
You donīt know the power handling of the original transformer.
And the secondary voltages of the original transformer might also be different.
Old 9th January 2018, 06:53 AM   #3
Thanks for your reply, after a lot of search on the net I may found the wiring diagram for the MA160 amp with the original power handling of the transformer and it looks quite different. (attached)
Its seems I need to find a 20-0-20 VAC, 33-0-33 VAC output transformer.
Old 9th January 2018, 05:31 PM   #4
Now I guess the power handling:
300W/400W.
Old 10th January 2018, 11:37 PM   #5
MAAC0 is offline MAAC0  Portugal
According to this it's a 160W amplifier
PROEL - SMART SMTV12MA - MONITOR AMPLIFICATO - Zecchini - Strumenti Musicali
The high AC could be main power and the low AC could be pre-amp power. Follow the traces and the capacitors after should tell You what voltage the board is expecting.
Old 10th January 2018, 11:45 PM   #6
Schematic and parts download here. Just wait that processing stuff..
PROEL SMART 12A AM160 AM161 AM321 AM320 AM320S SM Service Manual download, schematics, eeprom, repair info for electronics experts
Old 10th January 2018, 11:46 PM   #7
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
It could be crossover distortion because of inadequate bias current due to the low voltage supply
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Distortion sound at all volumesHide this!Advertise here!
Distortion at high volumes dbutler6259 Full Range 18 20th July 2015 04:55 AM
Distortion at low/medium volumes in speaker emperor Multi-Way 26 19th November 2013 12:58 PM
modulation-like distortion of music at low volumes fez79 Headphone Systems 1 16th October 2012 08:00 AM
TDA7240 Distortion at low volumes scwhiteley Chip Amps 5 26th October 2011 02:16 PM
Speaker Volumes? ...as in space not sound. BlueWizard Multi-Way 1 25th August 2009 11:26 PM
