PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Math question - Speaker in parallel
Old 7th January 2018, 03:56 AM   #1
livingtool is offline livingtool  Argentina
Question Math question - Speaker in parallel
Hi all. I'm Pablo from Argentina.
I'm putting together a medium PA system.
4 x 350watts full range, 8 ohms, passive speakers (2 for each channel, in paralell)
Digital Power Amp with a 1200watts per channel at 4 ohms.
As I understand it, each channel will have a load of 4 ohms and add to a maximum of 700 watts.
That will leave a 500 watts headroom, taking into account the "rule" of "1.5 to 2 times the amp".
Is my math ok? Thanks for the help.
PS: sorry if my english isn't so good.
Old 7th January 2018, 07:20 AM   #2
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
Yes, this is correct.
Old 7th January 2018, 07:37 AM   #3
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Also the damping factor will halve.
Old 7th January 2018, 10:33 AM   #4
The damping factor is 1/output resistance of amp.
Old 7th January 2018, 10:38 AM   #5
Yes.
It will be half on 4 ohms compared to the 8 ohms load.
Old 7th January 2018, 06:31 PM   #6
conanski is offline conanski  Canada
Depends.. is that 350w speaker rating at rms, program, or peak?
Your math is good but unfortunately sizing amps is not that simple. That "rule" was developed when music had relatively high dynamic range with short duration peaks and the suggestion was to have an amp capable of up to 2 times the program rating of the speaker to be able to deliver music peaks without clipping the amp.
With the way the most popular genres of modern music are mastered for maximum loudness these days(almost zero dynamics), if you were to put that much power into a speaker it will only last a short period of time. So you need some way to limit amp output to something the speakers can survive on a case by case basis. Do your amps have adjustable limiters and are they simple peak limiters or are there rms limiters too?
Old 14th January 2018, 10:12 PM   #7
Ron E is offline Ron E  United States
Ron E's Avatar
Damping factor = load impedance / output impedance
...and halving it is not a problem.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 17th January 2018, 08:48 PM   #8
Not for you.
Old 17th January 2018, 08:52 PM   #9
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Amp power 1.5 to 2 times speaker power will fry your speakers nicely if you don't take care !
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 8th February 2018, 10:29 AM   #10
Ron E's Avatar
Not for you.
Not for anyone who understands it.
Can someone explain damping factor
Math question - Speaker in parallelHide this!Advertise here!
Easy math question WagBoss Solid State 4 27th May 2013 06:30 PM
True Power-- Math Question wdcw Everything Else 17 19th October 2010 07:40 AM
Instantaneous Voltage--Math Question! wdcw Everything Else 8 14th October 2010 10:33 PM
2 Question regarding Math Cad Sheets tda Multi-Way 8 6th January 2004 12:13 AM
radiation pattern math question blu_line Multi-Way 6 31st October 2002 05:04 PM
