PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Math question - Speaker in parallel
Old 8th February 2018, 10:40 AM   #11
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Theory is just theory.
What about practice?
Old 8th February 2018, 11:46 AM   #12
livingtool is offline livingtool  Argentina
Ok, so in one hand, my math is OK.
In the other hand, 1.5 to 2 times Amp power will fry my speakers.
I guess this is not a exact science for me...
My amps have 1 knob per channel. 1 to 10. Somewhere I asked if my amps are 1200 watts per channel, every notch was 10% of the full power.
The answer was: THAT IS NOT HOW ANY OF THIS WORKS.
And never elaborated on this.
Anyway, thanks for all the answers, but sadly I am as lost (or more) than before.
Old 8th February 2018, 12:26 PM   #13
Pano is offline Pano  United States
Pano's Avatar
The reason you are confused is that it's not a simple matter, and the answers have all been simple so far. Nothing wrong with simple answers, but in this case they have left you confused.
Headroom is your friend because it allows you to hit the peaks without clipping. Clipping not only sounds bad, it means much, much more power at the peaks than with a clean waveform. That's where much of the danger to your speakers comes from, hard clipping.
Yes, if you continuously run higher higher average power than rated, you will burn up the speakers. You have to be careful with that. An extreme example for me was running speakers rated at about 50 WPC on a 700 watt amp. I did manage to kill one tweeter, but that was on a test sweep signal that has equal level from 20-20K Hz. Mostly I found that if I limited to amp to 150W, there was no problem on musical content. You can also limit your amp to were you want it, and it will never clip.
Limiting was mentioned in some other replies, but it can be as simple as turning down the volume at the power amp. How far to turn it down is not a simple answer, but there are ways to approach it.
Take the Speaker Voltage Test!
Old 8th February 2018, 12:30 PM   #14
Thanks PANO!
Question on that: if the Clip light on the Amp hits red, does it mean the speaker is peaking or the amp is insufficient for that speaker?
I remember Seinfeld saying: find out what would kill you, then back up a notch.
Does that apply to this scenario?
Old 8th February 2018, 12:39 PM   #15
Pano's Avatar
Yes, yes it does.
Remember, if your amp is rated at 1200 watts into 4 ohms, that means 600 watts into 8 ohms, and that's what each speaker will see at max power. They are still 8 ohm speakers, so each of the two on a channel would just "see" 600 watts maximum.
But think about this: Even if you are running as loud as the amp can go with music., each speaker is probably only at 60 watts average.
Old 8th February 2018, 12:46 PM   #16
That is great!
Thanks a lot!
Old 8th February 2018, 01:20 PM   #17
silverprout is offline silverprout  France
silverprout's Avatar
When you jump on a trampoline and and its membrane don't absorb your body mass kinetic energy enough (not enough damped) your body crash on the ceiling because of the excess of stored energy in the damping springs.
Things I Should Have Learned In School (But Probably Didn't)
Old 8th February 2018, 01:38 PM   #18
Not if the room is high enough.
Old 8th February 2018, 03:38 PM   #19
conanski is offline conanski  Canada
Maybe.. maybe not. Depends on the music or program type.
It is just much more complicated than you anticipate.
No... it doesn't work like that at all. That control knob does not in any way limit output power it just changes how much input signal is required to drive the amp to full output.
We can still help more but you didn't answer the question I posted in my first reply either and that information is needed to further the discussion.
Old 8th February 2018, 03:52 PM   #20
The full range speakers are 350 watts RMS at 8ohm.
Since I first posted, I have added a fairly powerfull subwoofer, so the full range are now only for mids+highs.
Anyway, I'm aware that if the amp is bigger than the speakers I can blow them.
I just don't know if there is a way I can limit the power other than by hearing the clipping (or watching the red light) and then backing up a little.
So far I haven't blown anything.
I asked before if the red light means the speakers are clipping or the amps are insuficient for the speakers (I'm inclined for the first option), but don't know for sure.
Thanks a lot for your time!
Math question - Speaker in parallelHide this!Advertise here!
Easy math question WagBoss Solid State 4 27th May 2013 06:30 PM
True Power-- Math Question wdcw Everything Else 17 19th October 2010 07:40 AM
Instantaneous Voltage--Math Question! wdcw Everything Else 8 14th October 2010 10:33 PM
2 Question regarding Math Cad Sheets tda Multi-Way 8 6th January 2004 12:13 AM
radiation pattern math question blu_line Multi-Way 6 31st October 2002 05:04 PM
