PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Mic with strong midrange recommendation?
Old 26th September 2017, 07:26 AM   #1
6V6dude is offline 6V6dude  Australia
Default Mic with strong midrange recommendation?
I'm hoping there is someone here with mics experience. I'm using SM57 for drums but find it too harsh to use for guitar amp miking. So I'm using old Behringer XM2000S which suits me fine. I need another but not only they don't make it anymore, the big problem is that I have two of these mics, one with switch (S) and one without. Being Behringer quality, they both sound completely different. The one without switch has a big EQ scoop in the middle and no midrange and just sounds terrible. So I'm looking for a mic that has good smooth and strong midrange without harsh top end. Ok, I want as cheap as the Behringer but maybe that was just one off lucky good mics they made by mistake. Any tips appreciated.
By the way I asked Behringer for new model replacement, they never even heard of the XM2000. They don't know what they made 15 years ego, how about that.
Old 26th September 2017, 08:34 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The XM2000 is a budget mic.
Instruments are best served with either Beta57 or SM57 alongside a decent mixer will produce any sound you want except for a mouth organ and a bullet type, with a compressor, should be used for that application.
Ask any professional backline PA tech.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 26th September 2017, 11:04 AM   #3
turk 182 is offline turk 182  Canada
Sennheiser e609 is my preference for guitar amp miking.
on a tight budget the audix i5 gives good results.
technique will also have a profound influence on results.
using two mikes at varying distances is another thing to experiment with.
Old 28th September 2017, 07:51 PM   #4
Zwiller is offline Zwiller  United States
Like all things, mic and technique depends on what you're after. Metal/jazz/pick your poison. Dare I say if you cannot get something doable with a 57 something is amiss. There's a good chance the amp is set too bright so guitarist can hear on stage. After all, very few guitarist dial their tone in with their ear on the cab... The classic remedy (besides getting guitarist to change) is to move the mic off axis 45deg or even 90deg.
_____________________
Sam
Old 1st October 2017, 05:52 AM   #5
I used to use SM57 in the past as my main mic but that was for rock music. Since I'm doing 60's rockabilly type, I find the SM57 is harsh for that music. Just can't EQ out some the top end "fizziness" it has out of guitar or vocals without killing the tone I want. But for drums it works well.
I did try ribbon mic, that was a good tone but just not aggressive enough.
I guess I should have mentioned the style of music first, you'd have an idea what sound I'm in to. Often they just used generic mics, not boutique vintage ones as many people think. So I'm probably after some "generic" decent mic.
Old 1st October 2017, 01:24 PM   #6
generic decent mic describes a Shure SM 57.
one way of auditioning mic's is to contact local music stores or sound companies and rent an assorted mic kit.
close mic'ing always brings out harsh top end even an MD 421 will sound bad.
Old 1st October 2017, 01:43 PM   #7
Pano is offline Pano  United States
Pano's Avatar
I'm also in the "If you can't get something usable out of the SM57, there's a problem" camp. Ditto the Audix i5 is worth a try.
As others have said, try different angles or positions. Another old trick is a second mic in the back of the guitar amp. Mix it in to taste, flip polarity or not - and listen.
Take the Speaker Voltage Test!
Old 1st October 2017, 02:09 PM   #8
Pano i think that's a typo never heard of an SM 47.
Old 1st October 2017, 02:13 PM   #9
chris661 is offline chris661  United Kingdom
chris661's Avatar
SM57s (and a lot of modern mics) have a presence rise. Try a wide -6dB cut around 6kHz. It should still attenuate a couple of dB at 3kHz.
Alternatively, see if you can find a Beyerdynamic M67. They're one of my favourite mics ever, for the precise reason that they don't have the presence rise of most modern mics.
Chris
Old 1st October 2017, 03:38 PM   #10
Pano's Avatar
Yes, Typo. I'll fix it to SM57. Thanks.
Mic with strong midrange recommendation?Hide this!Advertise here!
Rubber bands + string hoist a weight. Cut a string, the weight *rises* (!!) Mark Johnson The Lounge 39 14th December 2016 02:00 PM
String mounted dipole phazer99 Planars & Exotics 15 30th April 2013 02:45 PM
String noise/squeek Robert Kesh Instruments and Amps 10 17th January 2013 05:46 PM
Air on the G string CarlyBoy Music 1 22nd May 2011 09:35 PM
HELP me re-string my Telefunken 4530 lskelly1 Parts 1 24th March 2008 08:35 AM
