PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Anyone interested in a plasticab bulk buy?
Old 11th August 2017, 03:27 PM   #1
nikmartin is offline nikmartin
Default Anyone interested in a plasticab bulk buy?
I've been kicking around an idea for importing a container load of pretty decent looking cabinets from China. I have a buddy that does some import/export trade and I've been looking to stuff my own PA cabinets for a while and decided to take a peek overseas to see what's available. Attached is a set of images of a cabinet that looks eerily similar to a few famous name cabinets. I'm awaiting confirmation of some samples to do some testing and measurements with. Worst case I end up with a pair of cheap cabinets to play with, but if they turn out to be decent, would be a pretty good buy based on shipping costs. I live in a container port city. My biggest fear is they are cheap polypropylene 'greasy plastic' instead of a more rigid material. Polypropylene is tough but super flexible so I wouldn't imagine the cabinets would sound good at all, very resonant and drum-my.
Old 11th August 2017, 08:39 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
They look similar to Mackie Thump and all the rest. They will be fine with plenty of wadding. What size drivers, 12 or 15"?
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 12th August 2017, 07:59 PM   #3
msibilia is offline msibilia  United States
I might be interested if it were for a 12 inch coax wedge, but not a 12 inch plus horn box.
Marc
Old 17th August 2017, 07:06 PM   #4
These are 15", they don;t currently have a 12" in this style.
Old 18th August 2017, 09:41 AM   #5
Kay Pirinha is offline Kay Pirinha  Germany
Is the horn driver dedicated to thread or to flange mounting? What is it's throat diameter?
Best regards!
Old 21st August 2017, 01:21 AM   #6
Imagemeister is offline Imagemeister  Canada
Unit cost including shipping to us?
Old 21st August 2017, 12:45 PM   #7
Hemisphere is offline Hemisphere
Interesting idea. The design seems pretty good. With a well designed laser cut grille and backplate they can probably be made to look as neat as a professional brand.
Any particular reason why the 15" though? I would have thought for a bulk buy a 12" would have much more appeal. 15" may have a slight edge when run as a standalone enclosure, but on balance the portability of a 12 and their enhanced suitability for use with external subwoofers makes them the more obvious all-rounder choice for plastic cabs imo.
Also, with cheap Chinese enclosures, the larger you go the more you're introducing risks of sub-par performance. Simple physics of a larger surface area introducing more opportunity for vibration under high pressure. You would think they would increase the stability of the enclosures in larger sizes, but they will be cost cutting wherever they can get away with it.
Anyone interested in a plasticab bulk buy?Hide this!Advertise here!
Help with bulk caps Andrewleclerc93 Class D 10 6th February 2017 02:04 PM
Any Kiwis interested in a bulk buy from PE or Madisound? Mos Fetish Multi-Way 1 11th October 2009 09:44 PM
Flat bulk grill. wafflesomd Subwoofers 10 9th January 2008 10:17 AM
Bulk Interconnect Cable Bengali Parts 3 6th December 2006 08:32 AM
