PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Looking for info on speakers
Old 13th June 2017, 04:25 PM   #1
george17859 is offline george17859
Default Looking for info on speakers
I recently bought 2 yamaha PA speakers and the mid range drivers are blown in both. The model number on the backplate is S500, I've spent weeks trawling the internet for info on them but to no avail. Not a single link or picture of them, its as if they dont exist. Have any of you guys ever heard of them? can provide some pictures of them if needed. Thanks in advance!!
Old 13th June 2017, 04:26 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Yes pics.
planet10 needs your help:
Let's help Ruth and Dave
Old 13th June 2017, 04:58 PM   #3
20170613_172854.jpgThanks for the quick reply, these are a photo of the front and the backplate with model number on.20170613_172925.jpg
Last edited by george17859; 13th June 2017 at 05:23 PM. Reason: picture didnt upload
Old 13th June 2017, 06:31 PM   #4
turk 182 is offline turk 182  Canada
those go back to the days before internet was around so finding online info is unlikely.
long before i would worry about replacement drivers i would check the crossover level controls and crossover in general.if these where the victim of feedback or long term "damp" storage it's likely the controls are "open circuit". while your in there you can check the drivers for continuity and verify what drivers are being used to determine availability of replacement diaphragms.
Old 13th June 2017, 09:05 PM   #5
Enzo is offline Enzo  United States
If you mean the horn driver? Is there a number on the driver? Like hopefully JA4208?
You can test the diaphragm for open with your ohm meter. Also possible the crossovers are at fault, but when I get in a pair of speakers with the drivers blown I usually suspect the drivers themselves and someone with a heavy hand on the volume knob.
Looks like the original is superceded. See bulletin
Old 13th June 2017, 10:19 PM   #6
First off thanks for the reply. That was the first thing I done check the Xovers and level controls and their all working fine. The woofers had been replaced at some point with eminence drivers which turned out to be ripped. I've since bought new and replaced them. My plan is to do away with the hf driver that has blown turning them from three way into two way " woofer + horn". My problem is I cant find any info on the horn driver to be to know what the cut off frequency should be when I build the new crossover.
Old 13th June 2017, 10:23 PM   #7
Thanks for the reply. As i said above checking the crossovers and the driver was the first thig i done and it is the driver thats blown. Yes the horn driver is JA4208 but thats working fine its the mid thats blown ( 3 way ).
Old 13th June 2017, 11:33 PM   #8
conanski is offline conanski  Canada
Remove the mid driver and horn from the cabinet and post a pic. Is this a 1 piece combo or does the driver unscrew or unbolt from the horn? Also post a picture of the crossover.
If you are going to build or buy new crossovers then you could substitute one of several good aftermarket drivers and build the crossover around them.
Old 14th June 2017, 12:39 AM   #9
Which thing is the mids? I see a woofer, a horn, and what looks like a tweeter or at least a hole right in between the other two.
My service center data base includes only a small bit of information - the model dates from 1986. It offers two bulletins, one I posted earlier, then the other older bulletin shows original part numbers:
Diaphragm assembly for squawker JA4208 NB074960
Diaphragm assembly for tweeter JA4205 NB095490
I mention this older bulletin because it refers to the 4208 as a squawker, which is another term for midrange. Thus my confusion.
Old 14th June 2017, 11:21 PM   #10
djk is offline djk
R.I.P
djk's Avatar
Diaphragms for the tweeter are NLA.
Diaphragms for the squawker are available, but expensive.
I would consider replacing the squawker with the Eminence part (as suggested in the SB), the complete driver is less than an aftermarket diaphragm, more rugged, and replacement diaphragms are about half the cost of the aftermarket ones.
If you want a tweeter, ebay, or adapt a different part.
Candidates for the Darwin Award should not read this author.
Looking for info on speakersHide this!Advertise here!
translinear speakers: any info on these speakers ksporry Multi-Way 11 1st May 2018 08:05 AM
Trying to get info on old speakers bastafari Multi-Way 8 14th January 2015 01:31 AM
Info On Utah Speakers deerefanatic Multi-Way 2 16th August 2011 08:50 PM
outside speakers what kind setup info 80yearold Everything Else 1 22nd June 2011 02:15 AM
Where to go to find info about old speakers? ChopperCharles Multi-Way 7 12th February 2008 11:51 AM
