stranger 500 watt circuit - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 18th October 2015, 09:30 AM   #1
prtk is offline prtk  India
Default stranger 500 watt circuit
i have a same strnger circuit for 500 watt and i am getting very high noise at 70 percent of volume neither above it nor below it. can anyone suggest me solution
Old 18th October 2015, 09:39 AM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Schematic with your voltages?
Support for Flying Mole Class D, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 18th October 2015, 01:08 PM   #3
it has uses 5200 toshiba 12 no.
please suggest me solution
Old 18th October 2015, 01:20 PM   #4
andrewlebon's Avatar
Stranger amplifier is a pa amp bad design with 10% distortion
"It's Better to try and fail than to never know and always wonder"
Old 18th October 2015, 01:22 PM   #5
Then please suggest me some good good amplifier design
Old 18th October 2015, 01:55 PM   #6
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
What kind of noise?
Hum/Buzz/Feedback/Scratch/motorboating/ticking/?
Post a sound sample or YT video showing it and what you do to make it appear.
As of:
..... really? ..... these guys are geniuses !!!!!!!! what do they do to always have 10% distortion?
Not 9% , not 11% but 10% all the time.
That said: Stranger are successful makers and exporters of PA amplifiers, complete with transformer outputs 2/4 ohms, plus 70V and 100V line, with a matching design. (similar to Ahuja) .
You suggest he strips the amp and builds an audiophool approved one inside?
One of those who claim 0.000000000724% distortion?
Simulated of course, never actually built and even if, no way to measure such low levels, just cutting and pasting what the simulation software claims.
Back to the OP, if it makes some strange noise only at an exact position of the volume pot and nowhere else, then it's probably a dirty/cracked/chipped pot track inside, and probably cleaning won't solve it, just replace the pot with a new one.
Old 18th October 2015, 02:08 PM   #7
it is a scratching noise and very loud.
i have two samples and it is same in both.
just increse the master volume to 70 percent and it goes high
Old 21st October 2015, 04:17 PM   #8
JMFahey's Avatar
1) does it make that noise with no music input?
2) have you tried cleaning those pots?
3) it's weird that two different amps make noise in the exact same volume pot position, but 70% is a reasonable point for the two internal tracks superposition, it might be a defetive pot batch with a problem in that area (fwiw I have manufactured potentiometers and that was one possible problem) , so worst case replace both with known, good quality ones.
Perfect Stranger - Innovative Amplifier Stee Solid State 4 24th March 2014 08:16 PM
my 250 watt tube amp can be a 500 watt tube amp for less than 2 bucks plus tubes speakerfritz Tubes / Valves 17 25th October 2013 12:50 AM
500 watt amp build jimmy audio Chip Amps 1 17th August 2010 03:20 PM
500 watt monoblock RogerG Solid State 45 12th April 2005 02:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
