PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Crown XTi 2002 or Behringer iNuke NU3000DSP?
Old 12th April 2015, 02:07 PM   #1
cochinada is offline cochinada  Portugal
Default Crown XTi 2002 or Behringer iNuke NU3000DSP?
Hello everybody!
Just to give you a little background information, I'm going to need some juice for my DYI speakers who will have an active section, each with four 12" woofers. 800W @4 ohms per channel is the bear minimum and the requirement of DSP is a plus because most likely I will need to do some EQ and apply some filters. I would also like to use a Linkwitz Transform as it will be a sealed box.
Does anybody have experience with these two options? Are they both capable for instance to implement a shelving filter (or Linkwitz transform) with lets say 15dB gain? And what about the minimum crossover frequency for the HP filter?
The literature and manuals available are not totally clear and I never heard any Crown amplifier although I have a Behringer iNuke already for my subwoofers.
Thanks!
EDIT: I forgot that Behringer announces maximum power instead of RMS so I would have to consider the higher model which about half the price of the Crown: the iNuke NU6000DSP.
Old 13th April 2015, 12:49 AM   #2
conanski is online now conanski  Canada
From what I have read the Crown sounds much better in fullrange applications but the Behringer has a much more flexable DSP processing system, and you should be able to download the control software for both and explore it's functionality without any amplifiers connected. The NU6000 produces about 2kw per channel at 4ohms with very demanding test tones, do you need that much power?
Old 13th April 2015, 07:17 AM   #3
This is only for the active woofers so we're talking about low frequencies only. I don't need 2000W but the iNuke NU3000 is bellow 650W@4 ohms (RMS) so it's a little under my minimum requirements for full linear excursion. Anyway the price difference between the iNuke 3000DSP and the 6000DSP is not that significant. I've downloaded already some application from Crown called HiQnet Band Manager but I can't do anything with it as everything is disabled. I didn't yet try the DSP application from Behringer but I will.
By the way those power figures from Crown are peak or RMS?
Old 13th April 2015, 09:40 AM   #4
ViennaTom is offline ViennaTom
There is a Band Manager "Demo" that works without amplifier connected.
From Crown, the latest software they recommend is Audio Architect.
Old 13th April 2015, 12:39 PM   #5
Thanks, I found this Demo mode and already played with it although I didn't try the Architect.
I don't know if the demo is different from the real thing but I don't expect it to be. I found the SW from Behringer to be much more intuitive than Crown's. They both have the same limitations as the minimum frequency for anything is 20Hz and the maximum gain is also the same (15dB). Crown has the option for defining delays whereas I couldn't find this on the Behringer. On the other side this one permits shelving filters with 6db and 12db/octave slope. The iNuke has something they call Dynamic EQ but the Crown has this 'Subharmonic Synth'. In either case I don't know what are the use cases. Basically those were the major differences I noticed.
Still confused about the specs from Crown tough and wondering which ones are closer to reality, as many manufacturers tend to be too optimistic.
Besides that, in either case I won't be able to define any filter bellow 20Hz which can be a problem but then again perhaps not.
Old 13th April 2015, 12:59 PM   #6
I have an XTI6002 and per my own measurements I, can say Crown does not inflate power figures, definitely not for the 6002, most likely also not for the other models. iNuke6000DSP is less powerful than XTI6002 (I have this one too), they do inflate the numbers, but it will still do about 2 x 1800 real Watts into 4 Ohms, which is great for the cost. Of course, there is no "2 x 3000W" for the inuke as stated by their marketing.
Old 13th April 2015, 01:03 PM   #7
Dynamic EQ is an EQ that comes into play only if some defined level threshold has been reached.
With Dynamic EQ you can have different EQ for different sound levels.
Subsynth is only useful for subwoofer use. It will add frequency content one octave below lowest tone and can fatten up the bass quite a bit, but usually requires to either reduce overall bass loudness or to buy much bigger / lower tuned subwoofers, otherwise overexcursion may kill them.
Old 13th April 2015, 01:26 PM   #8
And these real watts are peak to peak or RMS?
Since you have both models what is your opinion about them?
Old 13th April 2015, 02:13 PM   #9
RMS.
My opinion:
crown XTI is great! no discussion about this. but it comes at a cost.
iNuke6000DSP: just bought it because of the incredible price, betting that the price will increase. iNuke has noisy fans, and feedback before the LC filter (not so good for HF output impedance), but cost is king!!
Old 13th April 2015, 03:26 PM   #10
So comparing to the XTi which I believe has only one fan (?) this is much quieter?
Thanks!
Crown XTi 2002 or Behringer iNuke NU3000DSP?Hide this!Advertise here!
Crown XTI 6002 ViennaTom Class D 23 27th August 2013 08:59 PM
Crown xti repair troubles. bassetrox PA Systems 1 18th April 2013 11:05 AM
F/S Crown XTi 1000 nvrgdenuf Swap Meet 0 23rd June 2011 02:03 AM
Matching crown XTI with subs? doug c Subwoofers 18 2nd January 2010 04:19 AM
