Amp for Passive speakers - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 27th March 2015, 01:09 PM   #1
Lightbulb Amp for Passive speakers
I have a pair of 2-way speakers that are for a Hi-Fi System that is very old. I was thinking if I could probably add an amp and batteries in the cabinet to make it a portable speaker. Now, I know very little about speakers so bear with me.
Here's a picture of the speakers.
As you can see, it says 12.5 Watts on them, and from what I've read, this doesn't seem like much, which encouraged me even more to the idea of a portable set, since it wouldn't need too much power, right?
If I can't turn it into a portable speaker, what can I do with them?
Can I diy an amp circuit and put it in the box? What would the power source be?
Sorry for such naive questions
Old 27th March 2015, 01:33 PM   #2
What are you hoping to do with them? - they are simply low power (cheap) stereo speakers, not really much use for PA or instrument use.
Assuming you want a small low power 'PA' (for busking etc.) then you want far larger and more efficient speakers than these.
Nigel Goodwin
Old 27th March 2015, 02:32 PM   #3
They are actually loud. The Hi-Fi system isn't cheap at all.
I'm not looking for anything exceptional though. I just thought it would be a waste leaving them unused like that.
I thought I could use my phone to play some music on them when I'm out with my friends, that's why I wanted to make them portable.
Old Yesterday, 12:37 AM   #4
a couple of TDA2030 chipamps with an adequate supply (or two so each could be independent)
might just be the ticket at 14 watts max. should be an fairly easy project to cobble together and should fit in the enclosure.
and just so you realize you posted in the wrong section of the forum.take a look through the chipamp forum.
Old Yesterday, 01:20 PM   #5
We obviously have different ideas what 'cheap' means
Simply looking at those tiny cheap Chinese speakers in plastic cabinets with a single capacitor 'crossover' screams cheap at me - it might have seemed expensive to buy, but it's only a cheap low quality system.
Do you have the model number of it?.
As all you're wanting is essentially a portable radio (but without a radio ), those would probably do all you need. As turk 182 suggested, a couple of TDA2030's would be fine.
Nigel Goodwin
Old Yesterday, 04:28 PM   #6
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
You can't say "TDA2030" and "portable" in the same phrase unless you have access to small portable 28V batteries or something
The TDA2030 can work with just 12V , sort of, very poorly, not exactly the best choice.
The OP needs an amp which can be properly powered by a 12V battery, usually chipamps designed for car use .
Search EBay for some around 15W`chipamp , ready made board, and I suggest a 12.6V 4.5AH gel cell/alarm type battery, which is inexpensive, powerful , and still reasonably portable.
Old Today, 10:08 AM   #7
well thanks for denigrating a suggestion. i never claimed it was ultimate just a potential way to go.
here a link to something not using a 2030 seeing how it's apparently poo...
Compact High-Performance 12V 20W Stereo Amplifier | EEWeb Community
i guess looking at old car decks an recycling the output ic would be met with the same sort philosophy so i won't offer that up.
Want to trade for: RBH stuff-passive sub, sub amp bookshelf speakers hatrack71 Swap Meet 0 10th January 2015 08:03 AM
converting passive speakers to active steevo Multi-Way 16 3rd February 2011 01:59 PM
Active and Passive Speakers Together Spudbum Multi-Way 2 25th September 2010 03:15 AM
Running a passive sub with main speakers off an integrated amp! Village Plank Subwoofers 5 28th January 2009 02:10 AM
my first speakers! fullrange+passive radiator sintacto Full Range 3 14th May 2008 10:47 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
