PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
x-over filters measured with Smaart7 @ the processor outputs
Old 20th January 2017, 12:41 AM   #11
newbieForever is offline newbieForever  Italy
Thanks Timo, forgive my poor english.
I hope that, being a speaker essentially a minimum phase device, I will be able to achieve the desired result by choosing the crossover points in the drivers' linear band (and where the frequency response covers a wide angle) and to fix the remaining response irregularities using the Linea Research parametric equalizer.
Finally i'll try to reformulate my last question:
Using LIR's crossover topology can i obtain a betters drivers integration (less destructive interference) over a wide listening area?
Roland
Old 22nd January 2017, 01:48 PM   #12
Timo Beckman is offline Timo Beckman  Netherlands
You need to verify over a large area so onax-ofax horizontal and try to minimize the problems in the vertical plane.
If the driver used in your design is a coaxial one try to get a clean alignment on both planes onax-ofax horizontal-vertical.
With a 3 or 4 way design you'll run in to a multiple of the challenges described above.
Old 17th May 2017, 03:50 PM   #13
A small post on the difference between Time alignment and Phase alignment. Enjoy ;-)
https://timobeckmangeluid.wordpress....ase-alignment/
By the way No subs used in this screen capture and the main system's phase respons (a Fulcrum Acoustic FA22ac) has been modified via 2 Allpass filters for the purpose of this screen capture......
Old 20th May 2017, 04:56 PM   #14
So started working on this cool feature within the Powersoft Armonia software
https://timobeckmangeluid.wordpress....working-again/
Old 10th December 2017, 08:58 PM   #15
Finally got some work done today.....
Working On FIR Again. | Timo's World all around the globe
Old 11th January 2018, 09:06 PM   #16
It's still a x-over so here you go:
Acoustic X-over | Timo's World all around the globe
x-over filters measured with Smaart7 @ the processor outputsHide this!Advertise here!
Have I measured well my drivers? merlin el mago Multi-Way 12 24th March 2014 08:36 PM
Filters on Idle Outputs Mark Kelly Class D 6 21st September 2008 04:38 PM
Balanced outputs used as inverting & Non-inverting preamplier outputs gni Solid State 4 19th September 2008 03:25 AM
Self measured T/S bhg41088 Multi-Way 10 14th May 2004 12:09 AM
EMI ac line filters & RFI ac line filters. Are they one and the same? KevinLee Parts 1 8th January 2003 12:18 AM
