PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
PPSL Questions
PPSL Questions
Old 12th March 2014, 05:35 PM   #11
Cuppa Joe is offline Cuppa Joe  United States
A Qts of 0.312 might be optimal, but it isn't critical to get good bass from a PPSL. A slightly higher or lower Q just means a larger or smaller box. Perhaps you could establish an acceptable deviance from the ideal Q in order to allow yourself more driver options? For instance, I was also considering the Kappalite 3012LF, instead of using a 15" driver.
Old 12th March 2014, 10:42 PM   #12
CRESCENDO is offline CRESCENDO  United States
PPSL Questions
Right, I was still including drivers within a few qts points (.26-ish - .36-ish). I was mainly looking at 18" drivers, but I might want to look at 15" drivers due to the large port size increasing box volume quite a bit.
Old 14th March 2014, 04:47 AM   #13
Just as a personal preference, I would consider a 90-degree clamshell arrangement for a 2x18" box, hoping to reduce volume. Would it no longer be a true PPSL?
Old 17th March 2014, 05:23 AM   #14
djk is offline djk
djk's Avatar
That works, but saves no volume on the plenum.
The speaker in the photo is actually an open baffle PA speaker with dual 18's.
I will be building a (sealed) quad 12 version with a 60 V-angle later this spring.
Candidates for the Darwin Award should not read this author.
Old 21st March 2014, 06:22 AM   #15
Looks like a fun design, I'd like to hear some reviews. I've considered a 4x12" version with your original baffle for the Kappalite 3012LF. I also designed a variation of a 2x3012LF employing the same layout as those M&K subs for a bass guitar cabinet. The lower driver was lowpassed at 95Hz & the upper 12 was crossed at 400Hz 2nd order LR (insistence of the bassist; I would have crossed it at 800Hz) to a B&C 6.5" cone. He's happy with it.
Old 27th March 2014, 12:05 AM   #16
PPSL Questions
Is there much sonic difference between your standard PPSL and the 60 V-angle?
Old 27th March 2014, 02:08 AM   #17
djk is offline djk
djk's Avatar
I haven't auditioned the 60V type yet, the above photo is a hi-fi speaker.
Old 27th March 2014, 11:58 AM   #18
turk 182 is offline turk 182  Canada
Cuppa Joe
earlier in the thread you referred to a DBX driverack as "not the best" what is your objection or dislike with it?
Old 28th March 2014, 05:30 AM   #19
My main objection is how it EQ's the system using pink noise. It works fine for mids & HF, but it over-attenuates most bass frequencies. Also, it tends to add +10dB spikes in the midbass region at or near 160Hz. I'm guessing that it's trying to compensate for baffle step loss. Basically, I have to re-EQ by ear everything below about 200Hz. Otherwise, I have no problems with it for crossover duty.
Old 28th March 2014, 11:44 AM   #20
i understand what your saying there.
although it's good guide/reference measurement i too find that final tuning is best done by ear
PPSL QuestionsHide this!Advertise here!
A Thread for those interested in PPSL enclosures jamikl Subwoofers 677 9th January 2018 12:34 PM
6th order PPSL enclosure design. lbstyling Subwoofers 19 28th August 2015 02:37 AM
Looking to build 2x18" enclosure - PPSL? MemX Subwoofers 77 16th December 2014 07:09 PM
Driver parameter changes for PPSL, Ripole weinstro Subwoofers 1 21st September 2013 12:33 PM
Interesting PPSL sub. Boscoe Subwoofers 5 12th November 2011 06:43 PM
