PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Compression driver selection & Revision log
Old 25th January 2014, 10:56 PM   #21
conanski is offline conanski  Canada
Originally Posted by Joseph Crowe View Post
The QSC speakers that are currently in use are HPR-122i.
QSC HPR122i 12" 2-Way Powered Multipurpose Loudspeaker | Musician's Friend
Oh they're nice.. are you trying to better them with this build?
Old 26th January 2014, 02:35 AM   #22
Joseph Crowe is offline Joseph Crowe  Canada
The QSC's have quite a few issues that I don't really feel like going into right now but I'm already way past bettering them. They've served their purpose for the past three years and it's time to upgrade.
Old 26th January 2014, 04:16 PM   #23
The QSC's have quite a few issues that I don't really feel like going into right now but I'm already way past bettering them..
Sorry I wasn't trying to suggest the QSCs were the end all be all of powered speakers, they're a decent little box but they have been bettered by subsequent releases by QSC and others and I'm sure they can be bettered with a DIY design.
Old 14th February 2014, 03:51 AM   #24
Thetwinmeister is offline Thetwinmeister  United States
I am still working on acquiring those B&C compression drivers. In the mean time the Daytons work, and I want to throw in a little story here.
I do live sound reinforcement with the same band every Thursday night, but it isn't in a permanent location so we always have to load in and load out our own equipment. And sometimes the band likes to change around their instruments. Today I was told we would be doing an acoustic night, just the lead singer, two acoustic guitars, and a minimal acoustic drum set lacking a kick drum. Naturally, this means I would have no need to bring my huge sub, thus saving effort. Oh yeah, and the group right before us was scheduled to cut into our setup time, leaving us an hour where we normally have two or three.
It's a trap.
My drummer shows up with his electric drums. No time to change setup, we'll be sending the kick drum through the Beta-12LTA drivers without a HPF. These are 12" drivers keep in mind, in a sealed enclosure.
I was surprisingly very impressed with the performance of the LTAs. Defiantly, the bass was lacking impact. But it wasn't as if the kick drum was absent by any means. The over all level actually blended really well with the two acoustic guitars.
Beta-12LTA is a real workhorse. I will post frequency response measurements as soon as I get them; as soon as I find big, empty space.
In one thousand years, will they still be called the Thiele Small parameters?
Old 14th February 2014, 07:09 PM   #25
It's a trap.
Yes I've had many nightmares about being thrown into situations that were out of my control regarding live sound. One thing I have learned is that if anything can go wrong it will go wrong.
If you ever want to build a stellar sub I recommend an onken style enclosure being driven by the latest class D amps.
Old 14th February 2014, 09:27 PM   #26
I was not previously aware of the Onken style design. To my new understanding, it's basically a large reflex alignment box? At this point I'm trying to get smaller, however. heh
Have you had any experience with the Cubo 15/18 or Cubo Sub or similar types of designs? They seem appealing because of retaliative small size and good extension/sensitivity.
Old 14th February 2014, 09:57 PM   #27
Found this! Dual 15" Subwoofer project complete
Good Job--looks great.
Old 15th February 2014, 01:59 AM   #28
I've seen the cubo designs but I've never heard them before. Two things stand out about the cubo that concerns me, first is the lack of any imperial data regarding frequency response and efficiency. Secondly the horn length is very short and therefore would not provide any low frequency extension which is probably why I haven't been able to find any data on it. The onken style enclosure is a very large box, but it's been my experience that to get good pitch definition you need a large box. I've seen people dismiss the onken design but after a lot of thought I think it's doing something a little more than a basic bass reflex function. It seems as though the symmetrical slot openings are coupling all the air inside the cabinet. In a traditional ported enclosure there are air pockets that act separate from the main event causing rippled in the impedance and FR curves. The result is less pitch definition since there are spurious acoustical events inside the cabinet.
Old 15th February 2014, 02:31 AM   #29
You have me interested now. For various reasons including the one you stated, I have tried to avoid ported enclosures. Another big reason is as power increases port tuning increases in frequency-- not good!
The sub I built is sealed, but it's sealed isobaric push-pull. I am a huge proponent of isobaric push-pull. I don't have all the empirical data assembled to claim it can't be beaten by a single driver in cost or/nor performance, but I like what I've read and heard empirically.
As a home theater sub, what I built is fantastic. Plenty of extension with more clarity than you could dream of at the price point for the drivers I selected. It doesn't do fantastically on stage though. Just well. It's a good sub, but it isn't amazing like I want it to be.
As you may or may not know, isobaric configuration reduces the Vas to half of the single driver, thus reducing box size requirement by half. Unfortunately, it isn't all magic as you are still required much physical space to link two drivers where there would otherwise be just one.
None the less, I would like to get your opinion on the theoretical possibility of combining onken with isobaric push-pull. Based on your experience, is reducing the Vas of the drivers by half a good thing in the onken alignment? Would reducing the Vas translate to reducing box size in onken? If the answers to these questions are yes, then I will seriously contemplate building an onken box.
I will probably build a Cubo-something along the way anyway, if nothing else to take measurements. If it does actually work I rather like the concept.
Old 15th February 2014, 03:09 AM   #30
Yes isobaric will also work with the onken enclosure thus reducing the required internal volume to half. The other benefit is that the effective Fs of the drivers is cut in half so for example if your pro audio drivers have an Fs of 40hz, you would now have an Fs of 20hz! There is no free lunch though. With a traditional dual onken each drivers efficiency is combined so 92db x2 = 95 Db. But with an isobaric configuration your looking at 92 Db /2 = 89 Db. Which is why you don't see it used in pro applications. However for home theater it's perfect. Save space, get deep bass, and class d power is cheap. Isobaric does have another advantage too which is lower distortion, especially if the drivers can oppose each other, thus cancelling out the physical non linearities in the cone's travel. Also any non linearities caused by poor motor design will be overcome, so bad drivers tend to sound their best aka cheap inexpensive drivers on clearance from parts-express.
Compression driver selection & Revision logHide this!Advertise here!
cheap B&C NEO compression driver seanny Multi-Way 1 28th May 2012 07:30 AM
B&C Compression Driver and Horns warnsey Multi-Way 270 9th November 2008 09:33 PM
Copyright ©1999-2017 diyAudio
