Cheap tweeters for a 15" woofer. - Page 13 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 28th February 2014, 08:38 PM   #121
Originally Posted by TheTubeAmper View Post
Do you mean 3 way or tri-amped? Because I'm already doing 3 way.
So far the Behringer A500 seems great, stays pretty cool even when playing at about 3/4 power, and no fans (unlike the slightly noisy Crest Audio LA601).
3-way with a sub, really. You could choose to tri-amp or not to tri-amp. If you did tri-amp, you could change crossovers on the fly with foobar.
I thought the A500 was under repairs at one point, was it not?
In one thousand years, will they still be called the Thiele Small parameters?
Old 28th February 2014, 08:46 PM   #122
TheTubeAmper's Avatar
Oh you mean use both mids, the high, and sub. I suppose I could do that but when I think of it the first thing I see is dollar signs. I need to buy a different crossover arrangement, as well as build a new box to accommodate both mids. I might use both, but I'm leaning toward not, we'll see.
As far as the A500 goes, I still haven't gotten around to ordering the left channel's filter cap, so the entire left channel is just disconnected inside the case, one channel is more than enough for the mids and highs. I will fix it when I order the 10" and crossovers.
Read and Follow my posTs at your own discretion, and risk. I'm an Electronics and Audio Hobbyist who likes tube amps too! Please check out my projects at http://thetubeamper.com/
Old 28th February 2014, 08:51 PM   #123
You can test it absolutely free though! Modify your box for the 10", and forward face mount your closed back mid on top of the box, tri-amp, and then test out crossovers with foobar. You may like the results and decide it would be worth the investment. If not, you haven't lost anything.
Sounds good.
"Best" Woofer 50Hz - 300Hz & Hi eff, maybe 15" ?? bear Multi-Way 177 6th June 2015 07:16 PM
SIMPLE QUESTION: Can a 10" woofer give me the same bass of a 15" one? murillollirum Multi-Way 69 8th February 2013 11:25 PM
WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer Jimmy154 Swap Meet 2 5th October 2010 02:00 PM
RSC (radio speakers canada) 15" woofer, 8" midwoofer, horn tweeter perceptionchanges Swap Meet 0 29th May 2010 07:18 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
Copyright 1999-2017 diyAudio
