PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
reduce noisy of amp
reduce noisy of amp
Old 6th November 2013, 07:33 AM   #1
lcd950 is offline lcd950  Sri Lanka
lcd950's Avatar
Default reduce noisy of amp
I have made a STK4192II audio amp and a LM1036N preamp.
So when I connect this with my speakers it get little bit of noisy, When I reduce volume from preamp that noise also get reduce, but when I listen to the music that noise also comes.
So what kind of thing should I do for remove this noise. for make sound clear?
Old 6th November 2013, 08:15 AM   #2
Enzo is online now Enzo  United States
Sounds like your preamp is noisy then. Noise takes many forms, and it comnes from many sources. You need to know what kind oif noise you have begore we know what to do about it. Is it hiss or hum or crackling or just what?
Old 6th November 2013, 08:25 AM   #3
lcd950's Avatar
It is a hiss noise
Old 7th November 2013, 11:48 AM   #4
turk 182 is offline turk 182  Canada
a schematic and a picture of your project might help
Old 7th November 2013, 01:29 PM   #5
lcd950's Avatar
Here is both schematic amp and preamp
Old 7th November 2013, 03:47 PM   #6
Speedskater is offline Speedskater  United States
Speedskater's Avatar
The schematic's didn't load.
For a test try a different music source (maybe a battery powered one).
Kevin
Old 7th November 2013, 04:02 PM   #7
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Can you disconnect pre from power amp ?
Old 8th November 2013, 05:44 AM   #8
lcd950's Avatar
Old 8th November 2013, 10:35 AM   #9
stratus46 is offline stratus46  United States
It is a hiss noise
The data sheet for the 1036 claims 80dB sn relative to 0.3 Volt which to me is a bit noisy but livable. However, your power amp gain is 101 which seems WAY too high which would aggravate your problem. You might try reducing the 56K resistors in the power amp feedback down to 15k which will push the gain and noise floor down about 12dB. If you have sufficient volume control range you can leave it there.
G
Old 8th November 2013, 01:12 PM   #10
lcd950's Avatar
G
For LM1036N preamp I've used 100k volume controls.
I checked disconnecting preamp but noise still same.
But I didn't check with battery powered one, I'll check it.
Also I will post my project photos later, certainly.
reduce noisy of ampHide this!Advertise here!
Noisy Amp vento Solid State 13 16th January 2009 08:45 PM
Hepl me! Nice amp but noisy thanh Solid State 44 11th January 2007 06:02 AM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 04:07 PM
noisy smps on amp davesaudio Car Audio 1 11th November 2003 02:56 PM
ESP P3A amp, very noisy DaViruz Solid State 33 16th November 2002 06:07 PM
