reduce noisy of amp - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 9th November 2013, 09:33 AM   #11
Originally Posted by lcd950 View Post
For LM1036N preamp I've used 100k volume controls.
I checked disconnecting preamp but noise still same.
But I didn't check with battery powered one, I'll check it.
Also I will post my project photos later, certainly.
The range of the volume control isn't the value of the pot 47K or 100K. My suggestion is to reduce the gain of the power amps by 12 dB. If the gain of the power amp is too low you'll have to turn up the volume control higher which might be a problem. Reducing the power amp gain will reduce its' noise independent of the preamp.
G
Old 9th November 2013, 01:42 PM   #12
i could be wrong but it sounds like the original poster is trying to reduce the residual background noise that every amplifier makes this could a difficult chore as the source of noise could be the stk itself.
Old 9th November 2013, 04:24 PM   #13
Dropping the power amp gain from 101 to 26 may quiet it enough to take it from annoying to OK.
G
Old 26th December 2013, 07:58 AM   #14
lcd950 is offline lcd950  Sri Lanka
lcd950's Avatar
here is one image of my amp
Old 27th December 2013, 01:04 AM   #15
well a picture is worth a thousand words.worrying about noise when your circuit has no shielding. and your heatsink is that grounded?
it also appears that there's no shielding on the input wiring?
Old 13th October 2015, 06:32 AM   #16
lcd950's Avatar
MY NEW AMPLIIER
Old 13th October 2015, 06:39 AM   #17
lcd950's Avatar
Noisy Amp vento Solid State 13 16th January 2009 08:45 PM
Hepl me! Nice amp but noisy thanh Solid State 44 11th January 2007 06:02 AM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 04:07 PM
noisy smps on amp davesaudio Car Audio 1 11th November 2003 02:56 PM
ESP P3A amp, very noisy DaViruz Solid State 33 16th November 2002 06:07 PM
Copyright 1999-2017 diyAudio
