PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
scoop style midbass horn.
Old 24th October 2013, 04:01 PM   #22
turk 182 is offline turk 182  Canada
ok not that i'm intimately familiar with mini dsp but i'm pretty sure they have delay functions built in that could help.
the other thing i'm wondering is have you experimented with the relative phase of low to mid high?
in the days of old when crossovers didn't have phase selection it was almost standard practice to "invert" the mid with respect to the low in order to smooth the response across the crossover region.i'm probably wrong but not knowing how steep your filters are you could be getting phase cancellation between your sub and mid high box.(which can be worse or better depending on the distance between the two)
Old 24th October 2013, 04:09 PM   #23
ah a karlson freddi good thinking!
Old 24th October 2013, 10:27 PM   #24
klampykixx is offline klampykixx  Australia
heres my setup.
and i have previously set it up like this,
my aim is to end up with 6 subs perside, and to have as many tops needed to work with it. when i finally end up with enough, they will get stacked like my first pic, but obviously 6 instead of 4.
do the karlson style have good projection? it looks like the curtains would hinder output?
Old 25th October 2013, 12:11 AM   #25
indeed the karlson's are good projectors!
have a chance to explore potential phase problems?
if you want more info on the karlson's check out the karlsonator thread or reach out to xrk971 or freddi
Old 25th October 2013, 01:45 AM   #26
last time the system was out i played with delay and phase, noticed a decent change with delay, but phase didnt seem to make much if any difference.
ill check out the karlsons.
Old 25th October 2013, 03:50 AM   #27
where you delaying the low or mid band? and by how much?
Old 25th October 2013, 04:15 AM   #28
i delayed the tops, i didnt collect the time, but it was estimating approx 1.5m of delay.
the crossover filter is approx 80 @12db/oct on bass, and about 120hz@12db/oct on the tops.
any higher on the bass and it sounds a bit hollow, and any lower on the tops and it starts getting to excursion limits.
Old 27th October 2013, 11:02 PM   #29
Brian Steele is online now Brian Steele  Grenada
As the bass are THs, I suggest using a higher-order filter if possible. 48db/oct if possible. You can then run them a little higher before they start to sound "hollow".
Another idea - use something like HolmImpulse to measure the effect of using delay in the x-over region. It should be to difficult to find the best setting.
www.diysubwoofers.org
Old 28th October 2013, 02:04 AM   #30
imo i felt they sounded better with a softer slope on the XO.
in other news, i stumbled upon FreeSpeakerPlans site and quite like the MT130 cab. in triples, i can get flat from 90-300hz at 108db@1w. in singles, the lowest response was at 100hz, which was at approx 100db@1w but picked up to 105db(200hz) so if i knock the 200hz down on the EQ i could end up with reasonably flat response and still be louder than i am now on the same power.
which is what im looking for.
i know the MT130 is a FLH rather than scoop/TH but the FLH will also help with upper mids too. so kills a couple birds with one stone, and are reasonable sized too.
scoop style midbass horn.Hide this!Advertise here!
Difference between Super Scoop and Folded Horn Subwoofers ClackS02 Subwoofers 93 24th July 2015 12:00 PM
JBL 4530 scoop with 4560 front loaded horn Oliebaron Multi-Way 1 1st November 2012 07:35 PM
Driver for Midbass Thump? done OB style Antripodean Multi-Way 14 22nd July 2009 01:55 AM
TL and the derivatives using two midbass drivers in a D'Appolito style configuration Puggie Multi-Way 7 7th January 2005 03:04 PM
Help! With a rear horn loaded scoop bass bin slicemaster101 PA Systems 38 17th October 2002 10:38 AM
