All Horn System Build - Page 3 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 11th September 2013, 12:11 AM   #21
Originally Posted by sine143 View Post
yeah, fat chance I'll ever be able to afford them, but somebody else might
So did you buy the boxes or did you buy the drivers for cheap ?
2 barely used boxes and drivers. And two brand new boxes without drivers.
Old 11th September 2013, 12:54 AM   #22
sine143 is offline sine143  United States
sick, lucky find. only 4 drivers to buy, not too big of a deal. the sheer size of those in my house would be motivation enough for me to finish the system LOL
Old 11th September 2013, 01:07 AM   #23
Thats what I'm hoping for hahah, and I live in a studio.... taking up all my space ha
Old 11th September 2013, 06:04 AM   #24
wg_ski is offline wg_ski  United States
btw, heres my rough start sim on the 18SW115 horn (4stack) compared to the lab sub (in a 4xstack). fold forthcoming . should fit in half the size though maybe
The $64k question is: What could you do with the SW115's if you didn't limit yourself to half the box size?
Old 11th September 2013, 06:42 AM   #25
oh a lot more. trust me, thats where I started.
I've tried to lift a labhorn before.
I weigh 107 pounds, and my only other crew is my 85lb girlfriend.
we are not moving it if it weighs over 170.
basically, for the same number of drivers, pick up 4 to 5 db in output, and a handlful of hertz in extension.
did I mention I live in 420 square feet of apartment? (or 2940 cubic feet lol, 110 is already dedicated to subwoofers)
Old 12th September 2013, 03:19 AM   #26
If I used a 5050 for two and 4050 for the other two would it make much of a difference?
I just came up on a good deal on a 4050.
Old 12th September 2013, 01:30 PM   #27
I'd buy it anyway, even if you were going to upgrade later. When you start building these things, you can never have enough amplifiers.
Old 12th September 2013, 03:10 PM   #28
But for now on a right budget I don't really want to buy a 4050 and then another 5050 if needed. Will two labs max out the 5050 and therefore have lower output with the 4050?
Old 12th September 2013, 04:52 PM   #29
Depends if you're running series or parallel. If you're running the drivers in series I'd hold out for another 5050 (but use the 4050 for low mids). If you run parallel drivers, you might set your limiters a bit under the 4050's max output, then you'll end up with the same power out of both. Slightly higher peaks out of one won't be noticed.
When running the monster system, I run 6 off three CA18's and the other two off a 5050. With the drivers in parallel. Limiters are set to 90V peak and only 40V RMS to keep the heating under control. It never seems to come to that - with that many boxes the system runs on a headroom basis and is clean as a whistle... that can be heard for a mile in any direction. When I run TH18's (which is more often now) I run two per side on the 5050 - with the limiters disengaged. With the 35Hz high pass the amp just can't hurt 'em. And when the kids see clip lights flashing they know it's loud enough.
Old 12th September 2013, 11:36 PM   #30
Would I need two 4050s for the low mids? (obviously driver dependent) just wondering in general what kind of power I should be putting into the low mids compared to the lows.
Thanks so much for your help
Multi-way Horn System rocksteady40 Multi-Way 23 1st December 2012 01:06 PM
Horn Build using a tapped horn as a frame?? 3GGG Multi-Way 1 18th January 2012 12:52 AM
Mono Horn System-Edgar Show Horn? fergs1 Multi-Way 4 23rd August 2011 05:13 AM
2 way BR/Horn System minhaj Multi-Way 0 8th March 2011 07:36 AM
Three way horn system pelanj Multi-Way 28 11th August 2008 02:16 PM
Copyright 1999-2017 diyAudio
