All Horn System Build - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 10th September 2013, 08:08 AM   #11
stewin is offline stewin  Kenya
Originally Posted by sine143 View Post
whats up underslung. glad to see you're getting into soundsystems (Hennessey/dirtygypsy here)
the labhorn is a great box (Reconstrvt!!!), but with a little research you might be able to find something better .
that being said... are you dead set on the Labhorn? you got people to help you carry em
labs are the best they have won the shootout for like since they were invented. Both in clarity and loudness. the only disadvantage is their weight. :big grin:
Old 10th September 2013, 01:56 PM   #12
wg_ski is offline wg_ski  United States
Originally Posted by underslung View Post
Indoor and outdoor events for djing. And to compete with scooped setups in sound clashes.
So you've decided to use the real "lab horn" after all?
Old 10th September 2013, 02:12 PM   #13
Not the only disadvantage. Power compression is up there pretty high on the list too - and the only way to mitigate that is more weight (more boxes). If you do that, things can get really interesting.... but it's a heck of a job to set up.
The motors on the B&C's we can get now were a pipe dream back when the lab was invented. What I'd like to see is a modern implementation, using a modern motor - that can keep up small-signal. In both output at 2.83V and extension. Which would smoke the old design when hit with 1500 watts of average power . I doubt it would weigh much more, and a big stack would be incredible. Get into an SPL clash with THAT and you'd be getting somewhere.
Old 10th September 2013, 03:44 PM   #14
sine143 is offline sine143  United States
Theres a reason danley sells the dbh218 and gave the labhorn away for free imo same size, similar weight, smoother response more extension, more powerhandling. Makes sense theres a pair of big honking bc neo 18 inside. Bin fact it looks like just one 18sw115 in a flh will handle similar voltage to a series wired pair of lab12, in half the box aize and still win in output with similar extension.
Old 10th September 2013, 06:53 PM   #15
Is there a reason you are using 2 rmx 5050s for 4 labhorns? do you plan on parallel (4 ohm boxes, ish) or series wiring (16 ohm ISH) the pair of labs in each box? in Parallel, the lab will take 50v, in series it will take twice that (100v). the rmx5050 puts out about 90volts into 8 ohms (not enough for series wired boxes) and about 70v into a 2 ohm load (still well above the 50v required by the labhorn) this means 4 boxes per amp (with par wired boxes) max, and your running near or below a 2 ohm load.
I would recomend a SINGLE Crown itech 8000 or 9000hd. at 8 (and 4 ohm) its rated for about 110 volts, meaning if you series wire your boxes, you can run 8! labhorns per amp easily. they can be found used for less than 2k.
Hey man!
I've already ordered the labs and only cause I got a smoking deal on them. I was going to go a lot smaller and build everything myself until I came up on these and couldn't pass them by. Same goes for the 5050, I got a deal on it (could buy three at the price for one used 9000hd). Basically all the purchased components I'm waiting to get deals on, the rest of the boxes I will build myself. Which is perfect cause I'm in no rush to get the system finished as I'm just doing it for fun.
Old 10th September 2013, 07:42 PM   #16
Dang 600 a piece on the 5050 is a good deal. My back doesnt envy you one bit though. How are your building chops?
Old 10th September 2013, 10:24 PM   #17
You should see what I got the labs for:-P
Old 10th September 2013, 10:59 PM   #18
did you actually buy the boxes themselves, or just the drivers?
btw, heres my rough start sim on the 18SW115 horn (4stack) compared to the lab sub (in a 4xstack). fold forthcoming . should fit in half the size though maybe
Old 10th September 2013, 11:15 PM   #19
Those look awesome. Boxes and drivers:-)
Old 11th September 2013, 12:07 AM   #20
yeah, fat chance I'll ever be able to afford them, but somebody else might
So did you buy the boxes or did you buy the drivers for cheap ?
Multi-way Horn System rocksteady40 Multi-Way 23 1st December 2012 01:06 PM
Horn Build using a tapped horn as a frame?? 3GGG Multi-Way 1 18th January 2012 12:52 AM
Mono Horn System-Edgar Show Horn? fergs1 Multi-Way 4 23rd August 2011 05:13 AM
2 way BR/Horn System minhaj Multi-Way 0 8th March 2011 07:36 AM
Three way horn system pelanj Multi-Way 28 11th August 2008 02:16 PM
Copyright 1999-2017 diyAudio
