PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Build cabinet for Peavey 18" Low Rider Subwoofer
Old 27th August 2013, 09:35 PM   #11
freddi is offline freddi  United States
freddi's Avatar
the Karlson may have lower distortion than the little tapped horn - but might have a bit higher cutoff as the rear chamber and system tuning will pretty much dictate the low end
Old 30th August 2013, 09:50 AM   #12
SIDEWINDER 18X is offline SIDEWINDER 18X  India
SIDEWINDER 18X's Avatar
Originally Posted by rhythmzdj View Post
i will purchase 2ea Peavey 18" Low Rider , need help with box size and ports would like to be at least 32" high x 24" wide x 24" deep to stack qsc hpr153i on top each subwoofer . will cross at 100hz or 80hz . would like to have sub go as low as 35hz and still hear it . i have two sp118 now with black widow 1801-8 speakers now only go dow to 40hz as per specs
I had build quite a few boxes in the past for Peavey 18" Low Rider. (Kindly open attached folder to view plan). It performed very well. I had even compared it with original QW118. The results were quite similar.
I had even tried the dual 18 design, QW218. All I can say It was the best sounding Peavey lows that I had ever heard. I mean both the designs, single & dual.
Old 30th August 2013, 01:34 PM   #13
With reference to the attached box dimension for the Peaver 18" low-rider in my previous post #12.
I had drawn a 3-d drawing of the box here again which might be of some help understanding the internal bracings and the port area.
Old 30th August 2013, 08:29 PM   #14
wg_ski is offline wg_ski  United States
Of course. The QW's are on the expensive side for a PV cab.
Old 30th August 2013, 09:45 PM   #15
rhythmzdj is offline rhythmzdj  United States
thanks SIDEWINDER that is what i was looking for ,will give it a go
Old 31st August 2013, 04:23 PM   #16
i will purchase 2ea Peavey 18" Low Rider.
Before you purchase the Low-Rider's, I would like to inform you that there are three generations of Low-Rider 18 produced by Peavey. All of these were marked with the same model no. (1808-8 HPS). All differ on the cones fitted with.
The earlier one had a Progressive m-roll surround / light weight composite fiber-glass smooth cone (American cone).
And the second one had a progressive two roll asymmetrical surround / heavy weight composite kevlar ribbed cone ( European UKM cone) . You can identify this one stamped UKM along with the cone no. at the rear of the cone.
Present generation Low-Rider 18 has a similar kevlar-ribbed / medium weight American cone like the UKM one. Both these ribbed cone sounds and performs better than the earlier smooth one.
As for my opinion the second one, the one with the European kurt-muller (UKM) cone is the best of all.
You can see both of these in the attached pics.
Old 5th September 2013, 06:08 PM   #17
awesome info Sidewinder ,when i purchase will ask ,and make sure not getting older generation
Old 28th October 2013, 09:28 AM   #18
LineSource is offline LineSource  United States
LineSource's Avatar
WinISD plots with T/S data:
GREEN: Early Peavey LowRider-18 with 163 gram Mms smooth cone. Note 7.8 ft^3 box.
ORANGE: Latest Peavey LowRider-18 with 198 gram Mms ribbed cone. Note 12.8 ft^3 box.
PURPLE: Beyma 18LX60v1 for comparison. Note 12.6 ft^3 box.
Typical comparison of box volume vs. bass F3 vs. SPL efficiency
Old 28th October 2013, 02:02 PM   #19
Do you also have a graph on the ribbed UKM cone low rider, which came just after the early Peavey low rider with the smooth American cone ?.
Old 16th April 2015, 07:30 PM   #20
AlexQS is offline AlexQS  United States
Default Correct application?
Hi, I'm planning to build a high sensitivity speaker to be used with my moderately low power (40 wpc) amp.
I have the 100 to 20000 range covered.
The peavey 18 low rider offers a high SPL 1m/1w and feels like it may be a good choice to cover ~30 to 100Hz.
How do you think this would work with only 40 watts in a small room?
Also, if my goal is to keep the bass as tight and musical as I can, is a small ported box better than a large ported box? (I know that choosing a different woofer designed for a sealed enclosure would be best, but I'm trying to save the cost of buying additional amps, and LT, etc for now). BTW, music only, no home theater use. Rock, jazz, not much if any hiphop.
Please share your thoughts.
Build cabinet for Peavey 18" Low Rider SubwooferHide this!Advertise here!
18" Peavey Low Rider venting jrbluejr Subwoofers 9 21st April 2013 12:24 PM
Peavey Black Widow 18" PA subwoofer design alberto82 Subwoofers 23 21st October 2012 07:48 PM
MBM driver 4012HO vs Low Rider 18 Reinyn Subwoofers 6 2nd February 2012 10:45 PM
DIY 18" PA subwoofer cabinet CruiSE Subwoofers 17 7th June 2009 07:28 PM
looking for peavey low rider (800 w) motor structure hunter audio Multi-Way 0 16th April 2004 08:48 AM
