Need SRM 450 V2 schematic/ Advise - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 26th July 2013, 01:11 PM   #1
Default Need SRM 450 V2 schematic/ Advise
I have a problem with one of my Mackie SRM 450 v2's where the high frequency driver intermittenly cuts out. It is, however mostly out now. The diaphram is good. I have pulled the amp and verified when failing there is no output to the HF driver. I have looked and tapped around the board looking for loose connections and bad solder joints but have found none. Does anyone have any ideas? I do not have a schematic for the V2 and it is vastly different from the V1. I don't think I can troubleshoot this problem without a schematic so if someone could let me know where I can download one I would much appreciate it. I am an ET with equipment so I would like to take a crack at it before taking it in for repair.
Thanks,
-Steve
Old 26th July 2013, 01:33 PM   #2
JonSnell Electronic's Avatar
It uses a switch mode power supply and class D output stages.
If it is less than 3years old, get it repaired under warranty.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 26th July 2013, 11:31 PM   #3
Enzo is offline Enzo  United States
And for the schematic, get the serial number from the unit, then call Loud Technologies and ask for the schematics. They will usually ask you to agree not to post them on the internet, then send them to you.
Old 30th August 2013, 04:43 PM   #4
SIDEWINDER 18X's Avatar
Thanks,
-Steve
I think this might help you !. Is this is what you were looking for ?.
Old 17th March 2014, 06:52 AM   #5
Check for a broken leg at TDA7294 and cold soldering at white connector to speaker
Old 17th March 2014, 07:03 AM   #6
Check in this picture
Looking for Energy Veritas V2.8 (or V1.8) Crossover Schematic dtm1962 Multi-Way 2 9th May 2017 09:57 PM
Tannoy crossover schematic SRM 12 Alois Multi-Way 7 12th April 2013 09:26 PM
Looking for AUDIO ALCHEMY DDE v2.0 schematic olaychang Digital Line Level 1 22nd July 2011 09:57 AM
Acoustic 450 schematic Terry Demol Solid State 0 9th August 2010 04:43 AM
Mackie SRM-450 12" woofers Magicdj Swap Meet 2 13th November 2009 08:43 AM
Copyright 1999-2017 diyAudio
