PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
battery powered p.a. system
Old 14th July 2013, 11:21 PM   #1
konnektor is offline konnektor
Question battery powered p.a. system
i want to build/locate a battery powered stereo p.a. system for street music performance.
it's the power amp i need guidance with most.
i need a preamp which takes line and mic level signals, preferably with 2 x phantom power on the mic pres, no more than 4 inputs total.
(at times, i'll also use a usb audio interface with my macbook which will give me all the inputs and phantom power i need, but it would be good to be able to play without a computer involved).
i'd use efficient 1x10" speakers, and i'd only need 20W or so per channel.
i'd need the batteries to last 4 hours minimum, assuming room temperature and fairly constant usage over that time.
my guess is that the technology is available, and a lot cheaper than is commercially available as a finished product...
any pointers?
Old 15th July 2013, 07:32 PM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
I have made tons of such amps with TDA2005 : 16W rms each driving a 4 ohm speaker.
You can use multiple amps fed from the same 12V battery, each driving its own speaker.
One of them will last 7 or 8 hours from a 12V 7A "alarm/gel cell" battery, 2 of them will last 4 hours.
Now there are some bridged class D amps for car radio with a little more power but specially more efficient.
Old 15th July 2013, 11:13 PM   #3
cool - thanks. if you have any links for suppliers of the batteries and those bridged class D amps, that would be helpful.
Old 16th July 2013, 04:29 PM   #4
mr. doom is offline mr. doom  United States
I use a 2050 chip @24v with two or six 10" drivers.
ClassD audio and 41hz have nice boards. The Sure boards are cheap but I have one that I run pretty hard and it is still going strong. 2020 chips will use less power @12v.
Old 16th July 2013, 04:52 PM   #5
csom is offline csom
csom's Avatar
Dear Sir,
Could you give me some idea/ share of the preamplifier section of this cute amp?
Warm regards, Som
Old 30th July 2013, 05:19 AM   #6
dangus is offline dangus  Canada
Searching ebay for TA2020 and TA2024 will turn up a bunch of amp boards.
If you have a source for old DVD players, some players had a karaoke mic input board that ran off a single 12V supply and included an echo/reverb chip.
Craig Anderton's classic book, "Electronic Projects For Musicians" has various circuits that could be useful. The book can be found as a PDF online, and people have created updated board layouts since Craig used some opamps with unpopular pin arrangements.
Old 20th August 2013, 03:14 AM   #7
cyclecamper is offline cyclecamper  United States
The key is going for efficiency. That generally means class-d switching-mode amps, and starting from 12volts you can find efficient car audio power amps that are plenty powerful. But car speakers are not efficient; go for horns if you really want coverage. And you need an electronic active crossover before the power amps, not a passive one at the speakers. That will do the trick.
Old 20th August 2013, 03:16 AM   #8
You also might check out Optima batteries or if you can afford it the new lithium motorcycle batteries are really light.
Old 14th March 2017, 09:51 PM   #9
Paule133 is offline Paule133
Hi. I have also tried building a simple PA system with 3 mike I/P's.
Seems simple ... Mikes -> preamp -> amplifier -> speaker.
However with preamp and amplifier running off same 12v power supply I get severe oscillations with the volume at less than halfway.
I've tried this with several different amps/preamps (even radio mike receivers) and always the same problem.
If I run the preamp off a separate battery then no problem.
I need to run it all off one battery so how do I get rid of these oscillations.
Warning! I am not technical with electronics so please be very gentle with me.
Old 22nd April 2017, 05:54 PM   #10
Gnobuddy is offline Gnobuddy  Canada
The problem you described occurs because the power amp draws a fluctuating current from the battery. In response, the battery voltage fluctuates slightly. When you feed the preamp from the same battery, those tiny voltage fluctuations get into the preamp, where they are amplified, and fed back to the power amp.
Now you have positive feedback (same concept as a microphone too close to the P.A. speakers), and you get oscillations.
The solution is to keep those tiny battery voltage fluctuations from getting back into the preamp. In most cases, this is quite easy to do - insert a resistor (R1 in the attached figure) in series with the positive battery rail. Connect a capacitor (C1 in the figure) directly from positive power supply rail to negative power supply rail in the preamp.
Together, R1 and C1 form a low-pass filter. They let DC electricity flow through from the battery to the preamp. But those small AC fluctuations in battery voltage are filtered out by R1 and C1, and never make it back to the preamp.
-Gnobuddy
battery powered p.a. systemHide this!Advertise here!
Want to build Unusual high powered battery powered headphone amp (and equalizer) bakalorz Headphone Systems 5 10th September 2012 03:17 AM
Need help with charging system for battery powered Gainclone jmillerdoc Chip Amps 3 22nd April 2011 06:35 AM
Battery-powered supplies vic2 Chip Amps 246 16th August 2010 04:07 PM
Battery powered amp Shpoop Chip Amps 8 26th January 2007 03:41 PM
Foam, Cardboard Horn? autosub? Ultra-efficient battery powered PA system required! biggerbyfar Subwoofers 2 15th January 2007 09:07 AM
