PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Ground lift switches
Old 20th October 2013, 07:23 PM   #51
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
noted, thanks
I will try with pseudo balanced RCA to XLR cable
and just have the other inputs as 'optional' with jumper, in case I'm missing a cable, or whatever might happen
time will show if makes any difference
anyway, I have planned to have instrument Jack input on front panel, with a buffer
back panel XLR input is only for extern preamp, or other units
sometimes we know very little, and sometimes we know too much
Old 20th October 2013, 07:36 PM   #52
I also planned to have a XLR/Jack combo
but that Jack is also balanced
so that will need som caretaking too
Old 21st October 2013, 06:45 AM   #53
Originally Posted by AndrewT View Post
Is that what Rane and Jensen tell us, when they suggest a converter cable? Keep the balanced for as much as possible. That must include the cable attached to the balanced impedance Receiver.
Andrew, its a single ended signal going into a balanced receiver
I do not see how to 'keep balanced signal for as long as possible'
Old 21st October 2013, 08:52 AM   #54
R.I.P.
The balanced input receiver is expecting a balanced impedance signal. Use a balanced cable to maintain the balance to as early as the system will allow.
Use the conversion at the output of the unbalanced source.
regards Andrew T.
Old 21st October 2013, 08:55 AM   #55
yeah, ok ... but it's not getting any balanced signal, either way
sounds very 'theoretical', but I will try it, sure ... but not expecting much difference, if any
if I remember it I will report back about it
thanks
Old 22nd October 2013, 09:16 AM   #56
hmm, I have always found that pseudo balanced single end cables sounded best with shield connecting to preamp
but only tried it with single end to single end, and never with RCA to XLR
but in the linked Rane paper, the shield is left floating
is that what a ground lift switch is doing ?
Old 23rd October 2013, 10:27 AM   #57
so, if I insert a mono/instrument jack plug into the balanced XLR/jack combo, it will automaticly short pin 1 and 3
so, a ground lift switch on XLR pin 1 would 'route' the single ended ground to XLR pin 3
Old 24th October 2013, 01:14 AM   #58
turk 182 is offline turk 182  Canada
wow it seems there's a lot of confusion about balanced lines and grounding practices.heaven forbid we start complicating matters with phantom power or A/D on balanced lines and maybe some high speed data too!
i guess i'm prone to mentioning phantom power and ground lifts because i've been there when some overzealous roadie starts flipping ground lifts with audio on and finds the phantom powered mic! many a horn driver has gone to speaker heaven in this circumstance.
when it comes to ground"lifting" anything exercise caution! an improper "ground lift solution" can jeopardize human life!
Old 24th October 2013, 09:34 PM   #59
well, many DIY'ers here couple the chassis and 'signal ground' via a resistor, diode, or thermistor
and some ground lift switches does that in the 'lift' position
but I 'out there' you never know what weird stuff comes your way
Ground lift switchesHide this!Advertise here!
balanced XLR patchbay with phase-reverse switches and ground lift cyclecamper PA Systems 19 25th January 2012 12:54 AM
Multi-channel Ground Lift Bigun Solid State 1 20th April 2009 06:43 PM
Active DI, Ground Lift, and Me slor Instruments and Amps 3 12th April 2008 08:43 PM
What means ground lift? Bassterror Solid State 11 16th January 2008 09:14 AM
Motorized projector lift (scissor lift?) JRace Everything Else 5 7th January 2008 03:11 AM
