Mixer Extremities Hardship - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 4th April 2013, 02:28 AM   #11
hewo is offline hewo  United States
Turk’s 1st line is mick jagger’s!
Worship captain is Danny_Jones <dandec3084@gmail.com>
Schematic is http://milas.spb.ru/~kmg/files/schematics/ampeg/vc508.zip Amp alterated little, 1000uf appendage 1st condenser, rectifier 3A 1000V, ac fan onto pt thermal stability, snubber on ac fan, snubber on toggle noise, edcor 15va pt 5k:8 for repro bass, ten watt 100 ohm el84 cathode bias resistor for demand stability, paktron foil poly coupling replace wima metalized foil for freq wide, celestion speaker replaced old philco whizzer television speaker threefold bigger magnet for bass. Dials 10am, 1030am, 10am per schematic flow, tele dials onboard 830am and 9am “tempered loudness” but if unthrottled to 530pm 530pm, about 2 to 3 acoustical watts. When amp dials furthered greater than five acoustical watts achieved. Tele dirt assigned by bridge pup or neck pup, clean both pups. Pups are stock tele yesteryears. The sensor is full range, scoped it to check range over sound generator. Laptop received analog and digital playback impressive! Don’t know whether embedded jfet in sensor blown by reversal jolt mixer phantom via reversed 50k:600 DI tranny. Captain experienced capacitor crackling sensor pa hot. Sensor is good stuff prior to if in fact blown. Digital file playback of speaker sounds impressive esp w/ experimentation where to plant sensor on the grill. Need be (excess distort) can use a repaired pedal I fixed, called washburn stack in a box 1970 era, cascade jfet five stage, unbelieveable rich harmonic twobee emulate but 7ma drain excessive battery cost. Pinkmouse wagered my ears are history from guitar desensitization noise levels. Worship captain might be correct? But dials show only two to three acoustical watts and schematic does not deceive SE el84 five watts max electrically not acoustically. Loud is the original mark one santanna quartet 6L6 class AB. But it is too heavy to lug for hundred pounder guitarist.
mixer Antonio Tucci Chip Amps 0 4th December 2010 04:51 AM
Mixer swaroopvg Subwoofers 1 11th July 2006 08:51 AM
How to recap a mixer? funkfaker Parts 2 28th August 2005 05:45 PM
potentiometers in a mixer zahlm Parts 0 6th May 2004 08:50 PM
Mixer schematics HELP!!!! Ze Chip Amps 3 23rd April 2004 12:55 AM
Copyright 1999-2017 diyAudio
