PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
DIY Mixer Repair.  Leaking capacitors?
Old 3rd March 2013, 01:50 AM   #11
mcno91 is offline mcno91
Originally Posted by Nigel Goodwin View Post
As it's two side by side channels, has it been struck on the knobs? - breaking the tracks inside the potentiometers.
I've seen two mixers like that, one a small mixer I bought off Ebay (which presumably got damaged in the post), the other a much larger mixer which had a good number of smashed pots - in a largish circle, obviously been hit by a football, with the centre pots smashed more than the outside ones.
Turned out the lady it belonged to had a young son, and the mixer had been sat in the conservatory
Haha kids these days... And the mixer is in great shape (besides from the issue with channels 1&2). Nothing is cracked or smashed and the insides look great as well. At this time I do not think the mixer has been previously dropped or smashed.
Old 3rd March 2013, 10:25 AM   #12
Nigel Goodwin is offline Nigel Goodwin  England
It's not something you can see - a direct 'knock' on top of the knobs can break the track inside the pots, so a simple ohms test on the duff channels pots might be in order?.
It's something you'd find during routine fault finding (as I did), but without a circuit it's something that is easy to test for.
Nigel Goodwin
Old 4th March 2013, 07:03 PM   #13
Enzo is offline Enzo  United States
Samson is generally very responsive, if they do not respond by email soon, pick up your phone and call them in New York. Have the serial numbher of the unit handy in case they ask.
Old 5th March 2013, 08:38 PM   #14
Okay, I understand now. As soon as I can I will check. I've had to put the project on hold because of school but thank you!
Old 5th March 2013, 08:42 PM   #15
They were quite responsive and very courteous. Here's the real schematic now: FileSnack | Easy file sharing
Old 5th March 2013, 11:15 PM   #16
Just to promote my theory then, from the schematic I see that channels 1 and 2 do share U3.
Old 6th March 2013, 03:26 AM   #17
stratus46 is offline stratus46  United States
If that gunk is acid (capacitor filling) it will be water soluble but glue won't be. Get a wet cotton swab and try cleaning it. If it IS acid it has to be cleaned off. I've seen the acid dissolve the copper traces off the board. Acid must be removed from UNDER the caps as well and if they're leaking they need to be replaced so buy your Silmics or FMs or whatever and get at it.
Remove bad cap, clean the board, replace the cap and clean off the flux.
G
DIY Mixer Repair.  Leaking capacitors?Hide this!Advertise here!
NAD C372 Leaking Capacitors???? Help Please! ssingh819 Solid State 3 7th December 2011 05:12 AM
DIY mixer first project Bananasdoom Analog Line Level 2 23rd June 2011 02:18 AM
Possible leaking capacitors NAD 370 [photos] zaibatsu100 Solid State 1 20th July 2008 01:39 PM
DIY repair- replacing capacitors Sir Trefor Tubes / Valves 5 14th May 2005 04:07 AM
Can we repair aluminium can capacitors rajeev luthra Solid State 6 6th August 2004 04:58 AM
