| PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc. |
this might seem like a stupid question but here it goes, i recently baught a used cx 2310 crossover that i want to use for my sub, my sub is a peavey sp 2g full range speaker, so am i correct in the way i am hooking this up.
from the mixer out, to the input of the crossover, from the sub out of the crossover to the amp, or instead of using the sub out should i use the low out of the crossover, also on the back of my speaker there is a high pass and bi amped low pass, the low pass is the one i am using. also what buttons should be pushed on the cross over, i have never used a cross over before and just want to make sure everything is correct. any help would be appreciated |
#3 |
here are 2 pictures of the speakers i am using, the single one is for the sub
what does wrt mean? |
#4 | |
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#5 |
well i think that i have it hooked up right, i just want to be sure, not to familiar with this stuff
#6 |
The back of my Peavey SP2-XT (previous model to the G) has regular and bi-amp inputs. The biamp inputs are labeled "hi" and Low". If you want to use the SP2G as a sub, you put low frequencies into the "low". The 2004 specs on the SP2 say it has a NUtrik Speakon 4 pin connector for the bi-amp high and low. There is probably a picture of the pins of the speakon on the back of the speaker, there is on my CS800 amp. If you are using the SP2 as a sub, you use the "low" pins only. The crossover probably has labels on the output of "High" and Low" or something, I don't anything about those. If you don't have a matching speakon connector, farnell.com has them as well as Peavey.
Oh, there is a picture at the end of the spec. Pins 1+ and 1_ are the LF inputs.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300 Last edited by indianajo; 12th December 2012 at 08:38 PM. |
#7 |
If it was mine, I'd route the mixer out into the crossover, with it set to stereo 2-way.
Set the 2-way crossover to ~80Hz, and the sub crossover to the same (experiment to find the best results for your system). Send the crossover high pass out to the main speakers, and the subwoofer out (which is mono) to the subwoofer. This will keep bass away from your midbass drivers, so the range they are covering will be cleaner. Also engage the 25Hz filter - your speakers won't reproduce <25Hz cleanly, and attempting to do so will just eat up system headroom. Chris |
#8 |
All i want to do is run the peavey speaker as a sub (1\4 " jacks, so i guess im hooking it up correctly, out of mixer to iput of crossover out of sub out on crossover to the amp, now just have to what buttons i should have on or off, i could use some help there
#9 |
25Hz filter engaged, and that's about it if you only want a subwoofer crossover.
Try the phase invert button on the Subwoofer control to ensure you get best integration. It should light up yellow. Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#10 |
Thanks for everyones help, have beautifull bass, not overpowering, just nice and tight even at very high volumes
| Inside photo Behringer CX 2310/CX3400 | potepuh | Parts | 3 | 21st October 2010 08:41 AM |
| Problem with CX 2310 | Moondog55 | Multi-Way | 1 | 21st April 2008 12:40 AM |
| For Sale:BEHRINGER CX 3400 Super X Pro Crossover | DeonG | Swap Meet | 0 | 21st March 2006 07:35 PM |
| behringer cx-3400 and xlr | rv1890 | Multi-Way | 4 | 25th January 2005 07:23 AM |
| Behringer 2310 | Tazzy | Multi-Way | 6 | 9th February 2003 08:05 PM |
