Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 13th November 2012, 08:22 PM   #31
Pano is offline Pano  United States
Pano's Avatar
Please refrain from quoting the entire post just above yours. The quote button is handy, but resist the temptation to over use it! Thanks
(I've cleaned up the thread)
Old 13th November 2012, 09:19 PM   #32
eddie
still here
have you had a chance to do any x-over shopping ,horn selection.
Old 14th November 2012, 01:48 AM   #33
EddieL is offline EddieL  St Lucia
Got the x-over, it's a Nady CX-23SW 3-Way Stereo, Plus Subwoofer Crossover Nothing on the horns as yet. Really would like to talk via phone,lots to ask.
Old 21st November 2012, 05:49 PM   #34
wg_ski is offline wg_ski  United States
Piezo changes everything. IMO, it's not really worth it to bi-amp a speaker with a piezo HF driver. They just don't need any power and wouldn't benefit from it anyway. Input above 28V will kill them, and even short bursts won't give you any more sound. If you do bi-amp, only use something about 40 or 50 watts with your HF, and it will be loafing the whole time. Use about a 5 ohm resistor in *series* with it to keep the amp stable with the light capacitive load that they offer.
I'd just go ahead and screw on a real 1" exit compression driver, and cross at 1.6k-ish. The difference in dynamic capability will be night and day. A 50 watt amp may be enough, but use 100+ to have headroom. A light bulb limiter is a good idea unless you have RMS limiting capability ahead of your power amps, which you should set for an output voltage of 18V (40W, 8R)
Old 21st November 2012, 06:05 PM   #35
Thanks for the reply Wg. I have put in proper drivers and the system is up and running and sounding sweet. A big thanks to Turk who helped me through this.
Old 22nd November 2012, 09:58 PM   #36
hey eddie
what did you get for the horns?
turk
Crossover or not....... 503Timber Multi-Way 1 21st June 2011 04:51 AM
To crossover or not or ? asiquis Multi-Way 17 15th November 2009 03:52 AM
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Copyright ©1999-2013 diyAudio
