diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   PA Systems (http://www.diyaudio.com/forums/pa-systems/)
-   -   Looking for simple power amp schematics. (http://www.diyaudio.com/forums/pa-systems/221147-looking-simple-power-amp-schematics.html)
theb0b 8th October 2012 12:12 PM
I'm looking for solder by numbers power amp plans either point to point or with simple to etch pcb plans.
Some where in the 200-250W per channel into 8 ohm range.
Easily sourced and cheap components. I'm planning to build 6 channels for outdoor PA, so something reliable please.
SPL is more important than SQ. These are for Subs and mid bass.
Thanks in advance.
donpetru 8th October 2012 01:03 PM
1 Attachment(s)
I attached audio amplifier diagram below.
For more details, read this topic (use google translate):
FET300 - un amplificator audio simplu si performant - DIY & Kituri Electronice - Comunitatea Tehnium Azi
indianajo 8th October 2012 02:51 PM
Look at the TI National LME39810 (BJT) and LME39830 (FET) driver IC datasheets. Probably available from TI but I got my datasheets through the local farnell.com website (they stock them). One IC, 2 pass transistors, a circuit breaker, transformer, diode bridge, and two filter caps, 14 other parts, you're done. Some guy on Solid State forum is puffing a PWB kit he is selling for the FET version.
donpetru 8th October 2012 03:49 PM
@indianajo,
I think you mean LME49810 or LME49830 ??? Right?
franzm 8th October 2012 05:22 PM
See also https://sites.google.com/site/quasisdiyaudiosite/
theb0b 9th October 2012 11:30 AM
Thanks guys some nice suggestions there.
@franzm I'm really liking the Nbip300.
How do you think these designs would compare to something like a DX turbo?
franzm 9th October 2012 03:24 PM
Don't know DX turbo. I built the Nbip300. As a subwoofer amp it wasn't bad. It is simple and uses parts easy to source or to replace. But it has no protection.
dangus 9th October 2012 10:06 PM
It's nearly always cheaper to buy second-hand amps than build from scratch. Plus, name-brand amps have protection circuits and resale value.
Power Level - 500VA
Note that just one 500VA toroid power transformer from Plitron is about $160 (plus shipping). Figure on another $100 for a case, $100 for heat sinks, $100 for filter caps. Now a used Peavey CS800 or PV8.5C from the music store looks like a bargain. Check eBay for power amps within pickup distance; if you can avoid shipping, you have an advantage over other potential bidders. Try local sound rental companies; some of them must be replacing their heavy old amps with lightweight class-D amps and selling off the old iron.
theb0b 9th October 2012 11:24 PM
dangus, I appreciate that in some places used amps are cheap and available, in my place that isn't so.
If I build my own amps in a modular fashion, I have the capability to repair, and also the satisfaction of DIY.
Franzm, which of those amps has a low parts cost and protection?
nuwan 4th November 2012 02:44 AM
Originally Posted by donpetru (http://www.diyaudio.com/forums/pa-systems/221147-looking-simple-power-amp-schematics-post3193675.html#post3193675)
sir i triad to access to site True link you gave us. but i can't download non of the PDF document you attach there. could you help me to get that top & bottom pcb lay out & construction detail in English. i am new to diy sorry for bad English
thanks
nuwan
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
