PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Looking for simple power amp schematics.
Old 25th July 2013, 08:06 PM   #21
geraldfryjr is offline geraldfryjr  United States
A 28v-0-28V transformer will only give you no more than about 98 watts into an 8 ohm load and that doesn't not include any losses of voltage drop across the output devices and power supply rectifiers.
However bridged amp configuration will allow you to reach your power level goal using those transformers.
You may want to consider something like a BPA-300 using some LM3886's or even some TDA7293's or TDA7294's.
They have a lot of performance per price value!!!
For anything more into 8 ohms you will need to use a higher supply voltage and should consider a discrete version power amplifier or a design that uses TI's LME49810 or LME49830 and some power output transistors.
Paralleled TDA7293's can get you into that power range providing you use a proper higher voltage supply.
FWIW
jer
Old 25th July 2013, 10:25 PM   #22
wg_ski is offline wg_ski  United States
Put the trafos in series. +/-80V-ish, with 40V taps available. Just right for a nice low-heat class H at 250-300W/8R.
Old 26th July 2013, 12:27 AM   #23
theb0b is offline theb0b
I plan to put them in series, I think the DX DHR circuit was designed with this in mind.
Old 26th July 2013, 12:42 AM   #24
Originally Posted by dangus View Post
The ETI 466 amp may be worth considering. ETI-466 Amplifier Technical Review
That looks like a winner. I'm going to give that serious consideration.
Old 13th August 2013, 12:45 PM   #25
turk 182 is offline turk 182  Canada
hey b0b
are you starting to get the feeling that "simple power amp schematics"is a contradiction in terms
Looking for simple power amp schematics.Hide this!Advertise here!
Very hard to find - Brand Name: "power" - Power Amp APK/APX series schematics wanted tiefbassuebertr Solid State 5 14th July 2013 05:39 PM
Digam power amp schematics drumkeeragh Class D 0 13th March 2008 05:34 PM
simple power supply schematics getafix Chip Amps 8 12th October 2007 09:41 AM
Beginners Project: Need a schematics for a small simple EL84 SE (or PSE) amp Erik Johansson Tubes / Valves 2 15th May 2002 11:35 AM
Class H simple amp schematics djdan Solid State 1 14th February 2002 11:16 AM
