PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Still need assistance designing a midbass cab
Old 20th October 2012, 11:25 PM   #61
col is offline col  Australia
col's Avatar
Not exactly what you are asking for but this is a very good read for boosting up your understanding of PA stuff:
PA Systems
col.
http://www.minirig.org.au
Old 21st October 2012, 02:17 AM   #62
klampykixx is offline klampykixx  Australia
good read, ill have to go back through it later on. just skimmed thru it on my lunch break.
Old 6th November 2012, 04:32 AM   #63
turk 182 is online now turk 182  Canada
you may want to look at something like old JBL 4560 boxes
Old 9th November 2012, 12:34 AM   #64
i have fitted a behringer active XO into my rack. i will be running it this saturday in a reasonable sized resturant, ill be taking my two tops, and probably just one sub and will see how it goes.
then, next saturday i have the gig in the hall, so will be running all four subs. be good to get it up and see how it performs in that stage too.
Old 28th November 2012, 03:51 PM   #65
turbodawg is offline turbodawg
Hi, I posted this in your other thread....personally, I think lack of time correction is your biggest issue:
A few suggestions:
- Your cheap compression drivers are probably falling apart in the midrange at high volumes. Consider an upgrade to something like a selenium D220ti
- In my limited experience with PA speakers, I find that they are not nearly inert in the cabinet as good hifi speakers, causing the sound to sort of fall apart at the higher volumes PA speaker are used at. Consider additional internal damping, bracing and stuffing to your mains.
- Are you running time correction on your mains to delay them to match up with the SS15's? Because the tapped horns have a baseline group delay at crossover that will cause funky cancellations in the midbass and a clear lack of attack. Try the system outside and physically move the subs ~4-6 feet in front of the mains, and don't use EQ. Also experiment with lower order crossover slopes, if you have the option, but this may not be effective considering the tapped horn.
It seems that kick bins are fairly popular with the UK sound system guys, but you have to consider these are used in massive, refined systems with multiple large subs and large mid-horns which do actually leave a small gap in the kick region when used together. The pair of delta-12's should have no problem keeping up with the ss15's above 120hz if implemented well.
Old 29th November 2012, 05:13 AM   #66
bitSmasher is offline bitSmasher  Australia
bitSmasher's Avatar
IMO spend some time getting the most out of what you currently have before trying to design/build new boxes - a DSP LMS is the best place to start, along with a microphone/SPL meter and an afternoon in a big open space testing+tuning the rig.
Once you can identify the issues then you can rectify them... otherwise you'll probably end up chasing your tail and spend a lot of time/money in the process of trying to "fix" things without knowing what you actually needing to fix.
Also coincidentally I'm set on building 4x SS15 (with Delta 12LFA drivers as per thread discussion) and want to put BFM OT12s on top as well, 22" is the magic number!
Old 12th January 2013, 10:34 AM   #67
After some good quality listening time over the past few weeks i have come to know what i want to hear, and what im not hearing.
first problem, which i believe will be rectified, is replacement tweeters. changing from chinese Weconic 1inch compression drivers, to Selenium D220ti comp drivers, i think i will pick up a good amount of clarity and much higher response, hopefully freshening up my sound stage.
second problem, is (IMO) still not quite enough "slap" to the sound. it has kick, and its solid, but i feel its a tad soft from 200-500hz area. i feel thats due to a single 12inch DR on either side trying to keep up with a pair of SS15.
heres my last pictured setup
and heres what im thinking i need to replace the single 12s with>
i think an extra pair of drivers, in a sort of tapped horn arrangement tuned around the 100-300hz mark, pending on the drivers natural roll off (i havent started looking at response graphs yet)
the current cabs, loaded with the Delta12a sound nice, theyre loud, and theyre clean, but just lack a little. especially knowing that im wanting another 4 SS15s in the near future. i feel that as they are, no way. but perhaps, horn loaded and double the cone area, could be quite capable at being a good blend.
any suggestions or opinions?
Old 13th January 2013, 06:47 PM   #68
chris661 is offline chris661  United Kingdom
chris661's Avatar
Just try doubling the cone area.
A while ago I was amazed at the sheer volume and projection this tiny system managed:
Its a pair of 6"ers a side, MTM, ported cabinet.
I suspect a D'Appolito arrangement or similar, which kept the vertical dispersion narrow.
Try disconnecting the tweeter in one of your cabs, stack them so its MTM and see what you think. Compare that to one midbass running, see if the extra output is sufficient.
If it is, go modular: keep your current tops, get another couple of 12"s, put them in their own cabinets and sit them on top of your current ones for the extra output when needed.
Chris
Old 13th January 2013, 09:27 PM   #69
regarding the modular, yes, i have def considered that. and it would make life a litte easier to carry them round. but i figure if im making one, why not make the optimum one.
Old 13th January 2013, 11:29 PM   #70
klampy
i suggested in an earlier post that you look at jbl 4560 style cabs for good reason, the mid slap i think your looking for is in horn loading your mid.
no front loaded or direct radiator is going to keep up to your long throw subs unless you have alot of them with 1.21 jigawatts of power but that would only apply in the near field!
Still need assistance designing a midbass cabHide this!Advertise here!
Could the SA-310 bass cab be used for a bass and guitar cab? JThompson56 Instruments and Amps 14 17th August 2012 09:50 PM
Thiele guitar cab vs. ported guitar cab qingcong Multi-Way 2 9th January 2011 04:32 PM
what sounds best . . . Low Qts in small cab or higher Qts in bigger cab mikelm Subwoofers 18 15th July 2009 11:46 AM
need help for a designing an extra small bass cab dighom Multi-Way 7 23rd January 2008 02:05 PM
Designing a bass cab Afroghost Instruments and Amps 0 1st May 2005 09:37 AM
Copyright ©1999-2017 diyAudio
